1512 Pto Too Small
7 replies to this topic
#1 cumminsmannow OFFLINE
cumminsmannow
  • 100 Thanks
  • 294 posts
Posted May 30, 2014 - 07:25 PM
What other cubs can i get a larger diameter pto pulley from. I've had a 782 and 682 last year and the 782 had a way bigger pulley like a 6" and the 682 and 1512 had something like a 4-1/2".
Will a pto pulley off of a 782 fit on my 1512?
I already have the speed up pulley on its way for the deck but i think that in conjunction with the larger pto pulley would make a wonderful setup for mowing grass.
#2 cumminsmannow OFFLINE
cumminsmannow
  • 100 Thanks
  • 294 posts
Posted May 30, 2014 - 07:44 PM
#3 cumminsmannow OFFLINE
cumminsmannow
  • 100 Thanks
  • 294 posts
Posted May 31, 2014 - 06:08 PM
Nobody?
#4 cumminsmannow OFFLINE
cumminsmannow
  • 100 Thanks
  • 294 posts
Posted June 01, 2014 - 09:23 PM
Well from what i've found a couple specs on my pto. It is a 5215-46 has a 1" id and is 3" tall with a 4-1/2" pulley.
I found a different one with the same 1" id and 3" tall but has a 5-3/8" pulley part number 5217-9 warner. Would this work?
#5 cumminsmannow OFFLINE
cumminsmannow
  • 100 Thanks
  • 294 posts
Posted June 03, 2014 - 01:52 PM
Today i tore into my mower deck and found that only the center spindle has replaceable bearings. The outside 2 spindles are the unit bearing type. Is this normal or did a po swap the outer 2 to the different style. Also is there someone that has a pair of complete rebuildable spindles for my outside 2 so that i can have them all rebuilt and be good to go?
#6 cumminsmannow OFFLINE
cumminsmannow
  • 100 Thanks
  • 294 posts
Posted June 03, 2014 - 05:00 PM
Apparently i am posting in the wrong forum. Its been 4 days and gotten 50 some views but not a single response. I guess i will quit posting on gt talk and focus on onlycubcadets where people actually answer a post.
Thanks for the time guys!
#7 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted June 03, 2014 - 06:50 PM
Sorry no one has offered to help. I am not a Cub guy and only half a mechanic so I have no clue on what to suggest. I like the cubs, just can't collect them all. I hope you can get the help you need to get it going again.
#8 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted June 04, 2014 - 05:56 AM
Your 1512 782.  682should all have the same size pro pulley .  They did not change the pro to 6" till the 1641.  1861'2'3s...somebody might have sealed the clutch on the other tractors.   Do a little more investigating...keep us   posted.
  • sacsr said thank you
