Motor Mount Isolator For A Jd 214
4 replies to this topic
#1 lyall OFFLINE
lyall
  • 2,179 Thanks
  • 1,577 posts
Posted May 29, 2014 - 10:07 PM
I know I can buy some new ones off e-bay
I was thinking about make new steel plates instead of the motor mount isolator
I know the 69 and older JD 110 and 112 had their motor bolted to the frame
my question is will the vibration be to much?
has any body tried it?
  • A.C.T. said thank you
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted May 30, 2014 - 05:19 AM
I would think youd get alot of noises and rattles from the tin work
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 30, 2014 - 05:20 AM
I think that JD 214 does not have the balancer shaft which is a good thing for the engine because it is a major cause of engine failure.  That may make the engine a bit rougher than a solid mounted K321 with the balance shaft. I've never tried to run one without the rubber isolators. I have a 314 which also uses the isolators but they are expensive to replace and the engine vibrates badly when the isolators are shot, which most of them are if original parts.
  • GTTinkerer and lyall have said thanks
#4 1971Deere OFFLINE
1971Deere
  • 48 Thanks
  • 66 posts
Posted May 30, 2014 - 08:35 AM
Don't know which set you saw on ebay. I used these mounts in my 214. They are a lot cheaper than from Deere.(Obviously) Supposed to be American made also.
http://www.ebay.com/...d657b32&vxp=mtr
Edited by 1971Deere, May 30, 2014 - 08:38 AM.
#5 Trav1s OFFLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted May 30, 2014 - 04:22 PM
The 120/140 machines also use the solid mount on the k301/k321. I wonder if you could fab a mount an automotive poly piece but don't know where to begin...
  • lyall said thank you
