How To Repair Gas Tank Filler On Jd 140S
2 replies to this topic
#1 GTTinkerer OFFLINE
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted May 29, 2014 - 08:58 PM
On both of my 1974 JD140 gas tanks leak because the filler openings are bent up probably from a PO just letting the fuel can hang off the tank when refilling.  Any ideas on how to repair them would be appreciated.
#2 superaben OFFLINE
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted May 29, 2014 - 09:43 PM
If it is a quarter turn style cap, you can buy weld on "openings" and get a bold and brave welder to braze or tack them on for you.
Otherwise, I have been known to spend awhile with a pair of vise grips and channel locks bending and prying.
A big thick cork gasket on your tank cap is also a benefit in this situation.
Ben W.
  • GTTinkerer said thank you
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 30, 2014 - 05:24 AM
Ben's idea of a better gasket would be my first step. You may also be able to get a new gas cap with a better gasket that may work. If that doesn't help then you could try bending the top back into shape but personally I would only try that if the tank were empty and rinsed.
