Built This New York Rake For My Ford Lgt 145
14 replies to this topic
#1 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 29, 2014 - 08:12 PM
Hey Everyone,
Just completed another project for my Ford LGT 145.
Got this york rake from someone on craigslist for $20. Welded it to some supports for my tractor's modified hitch and voila!
Primed
Painted and installed
  • Gtractor, MH81, Texas Deere and Horse and 7 others have said thanks
#2 Rock farmer ONLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted May 29, 2014 - 08:22 PM
Now that's a tool I'd really like to have!
I have a class 1 at six foot wide.
But, it's not good for trails.
How's it work for you?
Looks like you might do better with a little more angle?
Joe
  • hamman, JD DANNELS and FilledTires have said thanks
#3 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted May 29, 2014 - 08:28 PM
   Nice!!!!!  I like it.
  • FilledTires said thank you
#4 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 29, 2014 - 09:00 PM
Joe
I haven't tried it yet. Tomorrow when the paint is all cured I am going to try to spread some horse manure with it.
What do you mean by "a little more angle"?
#5 IamSherwood OFFLINE
  • 8,391 Thanks
Posted May 29, 2014 - 09:18 PM
That's nice. thanks for the pictures.
I wish I had one of those. I can think
of dozens of jobs for it.
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 29, 2014 - 09:30 PM
I too have a cat1 6 ft for my ford 1500. Mine has a pivot so you can change the angle. Adjusting the angle helps determine how aggressive it is.
When you do not need grading it is the best tool for gravel drive/lane maintainence.
They are great at pulling gravel up from the pack and redistribution.
Your really going to like that!
Edited by JD DANNELS, May 29, 2014 - 09:32 PM.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 30, 2014 - 05:26 AM
Looks great. That Ford is turning into a real workhorse for you.
#8 AMCJAVELIN OFFLINE
AMCJAVELIN
  • 72 Thanks
  • 49 posts
Posted May 30, 2014 - 05:49 AM
looks good my friend
#9 Rock farmer ONLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted May 30, 2014 - 06:20 AM
"What do you mean by "a little more angle"?"
It is hard to tell from the picture.
But, I was thinking the teeth are vertical, or, leaning back.
You will want them angled towards the front to grab and move.
You may find it tends to roll over things instead of digging in.
Putting some weight on it may help. But, it looks to be heavy enough.
Gage wheels could be a good option too. Because these tractors are either up or down on the lift.
Joe
  • TomLGT195 said thank you
#10 TomLGT195 OFFLINE
TomLGT195
  • 3,822 Thanks
  • 2,811 posts
Posted May 30, 2014 - 02:58 PM
this is what joe means, look at the tines in the pic
also the attachment point so it swivels /angles
Edited by TomLGT195, May 30, 2014 - 02:58 PM.
  • Rock farmer said thank you
#11 Texas Deere and Horse OFFLINE
  • 14,792 Thanks
  • 15,492 posts
Posted May 30, 2014 - 03:25 PM
So the rake fingers are stiff enough to carry the material to low spots??
#12 TomLGT195 OFFLINE
TomLGT195
  • 3,822 Thanks
  • 2,811 posts
Posted May 30, 2014 - 05:23 PM
They should be. A quality tine is stiff enough for that . It should work like a grader that spreads as it flattens IMO
#13 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 30, 2014 - 10:12 PM
Hey Everyone,
I took it for a spin today,and the tines are vertical when they hit the ground, but they did a good job leveling gravel, and spreading compost.
The tines are strong but pliable with a little leverage. I hit a couple of roots, and they bent backwards. I straightened it out with a vice grip.
I can try to give them more of an "angle" by bending the tines a bit.
#14 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 30, 2014 - 10:13 PM
Thanks! And I have many more plans for it. I have an ATV snowplow, I am going to build into a Front End Loader attachment by winter.
#15 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 31, 2014 - 05:55 AM
Sounds like a great idea.  Have you seen the Johnny bucket and the Superior scoop. There is a company called Horst Welding that makes loader mounted snow blades. If you check their site it may give you some ideas on how it's been done by others.
