Manure Spreader
11 replies to this topic
#1 mow happy OFFLINE
mow happy
  • 12 Thanks
  • 6 posts
Posted May 29, 2014 - 05:38 PM
does any one know how or where to gat plans to build a small ground drive manure spreader to pull behind a 19-26 hp mower or atv?  does not have to be big only needs to hold 3-4 6cub feet wheelbarrow loads. Or what gear sizes would it take to drive the inside moving bars and the paddles. I don't weld but can have it done, the bed would be wooden as I do wood working and have made my own hand hay bailer and outher items for my little mini farm.     thanks mow happy
  • MH81, hamman and propane1 have said thanks
#2 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted May 29, 2014 - 06:02 PM
Don't know any answers to your questions, but I want to say,   :welcometogttalk:
We would love to see the mini hay bailer.
Try this:http://www.millcreek...t-spreaders.php
Edited by KC9KAS, May 29, 2014 - 07:00 PM.
  • mow happy said thank you
#3 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,632 Thanks
  • 5,042 posts
Posted May 29, 2014 - 06:29 PM
Welcome to GTTalk!
Here are a couple of compact spreaders in case you haven't already seen them.
http://www.countryat...respreader.html
http://www.loyal-rot...e_Spreader.html
Edited by Gtractor, May 29, 2014 - 06:29 PM.
  • boyscout862 and mow happy have said thanks
#4 Robert Webb OFFLINE
Robert Webb
  • 923 Thanks
  • 435 posts
Posted May 29, 2014 - 06:43 PM
they are PROUD of those things
#5 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted May 30, 2014 - 06:28 AM
Check craigslist there a lot cheaper when people realize how crappy a ground drive spreader works
  • boyscout862, ENafziger and mow happy have said thanks
#6 ENafziger OFFLINE
ENafziger
  • 256 Thanks
  • 254 posts
Posted May 30, 2014 - 08:47 AM
Uh-oh...I was thinking of getting one.  Are they not worth the money?
#7 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted May 30, 2014 - 09:15 AM
We had a Mill Creek it did work but the beaters didn't go fast enough or the floor slow enough if the manure has a lot of hay in it .
 If your doing a lot of shavings it'll work okay but the tires also slide in the mud. We put 12 inch wheel weights on to help that
  • ENafziger and mow happy have said thanks
#8 MH81 OFFLINE
Posted May 30, 2014 - 11:48 AM
You will want to find one with separate adjustments for web speed and beater speed. They will do a fine job, but you need to be able to "tune them to the poop" so to speak.
#9 mow happy OFFLINE
mow happy
  • 12 Thanks
  • 6 posts
Posted June 03, 2014 - 06:30 PM
#10 mow happy OFFLINE
mow happy
  • 12 Thanks
  • 6 posts
Posted June 03, 2014 - 06:39 PM
the hay bailer I made was from a pine straw bailer on the intrnet. all I did was change the dimentions to make a bail 36x19x15. the bolt holes are not accurate I adjusted for the spacing by extending the 2 arm length. all length have to be adjusted for what size you decide on to make.you can search for pine straw bailers on internet there are some diagrams with measurements. I can make a bail about 25 pounds depending how much I pack. will try to post photos.   hope this is helpful.       mow happy :thumbs:
  • GTTinkerer said thank you
#11 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted June 03, 2014 - 07:15 PM
I was thinking something like this:
#12 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted June 03, 2014 - 08:06 PM
We had the same problem with the wheels slipping so we put chains on the tires.
