Some Pics Of The J.d. Tractor Yard Racer We Are Working On
18 replies to this topic
#1 oldmanmopar OFFLINE
oldmanmopar
  • 125 Thanks
  • 83 posts
Posted May 28, 2014 - 07:55 AM
We are getting close to disassembly and paint. Just thought I would post some pics you all can look at. It started as a 100 and now has a 25 hp Kohler.  The motor will go to the shop for performance work. My son wants 80-100 H.P. He does all the machine work and building himself.
  • Alc, hamman, trowel and 5 others have said thanks
#2 TAHOE ONLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted May 28, 2014 - 08:15 AM
That's some nice sheet metal work!!!
Are they required to have some sort of deck on them?
is this for fun or do you actually have races in your area?
#3 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 28, 2014 - 08:47 AM
Interesting.  I've always wanted to go see one of these races.  There's a track not far from me but I never seem to get the time to go.  Good luck!
#4 oldmanmopar OFFLINE
oldmanmopar
  • 125 Thanks
  • 83 posts
Posted May 28, 2014 - 09:51 AM
There is a local race coming up on June 14th. he bought two others but was not happy with them. He wanted a Deere. A 100 came up so he bought it.. It has a snowmobile clutch and a 1.5 to 1 right angle gear box . The motor , gear box and rear axle are fully adjustable for belt and chain adjustment .
  • hamman said thank you
#5 JDBrian OFFLINE
  • 9,601 Thanks
Posted May 28, 2014 - 10:05 AM
Very nice fabrication work! What are you using for a rear end in it.
#6 oldmanmopar OFFLINE
oldmanmopar
  • 125 Thanks
  • 83 posts
Posted May 28, 2014 - 11:08 AM
It is a solid chain driven 1 inch axle  with an ATV sprocket and hydaulic disc brake. Axle blocks were fabricated to move the bearings outward for stability. The snowmobile style clutch  spins a mower deck right angle gear box which turns the drive sprocket.
Right now with the new gear box 1.5 to 1 verses the 1 to 1 that was on it . It is very quick. It spins the tires and pulls the wheels up. the settles down when the clutch starts to shift and hits over 60 mph
We are hoping to increase speed and with more HP. the clutch still drags the motor down on the top end with only 25 HP. 100.HP. should wake it up.
One thing I should tell you is nothing is ever fast enough with my son.
#7 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted May 28, 2014 - 03:12 PM
   Very nice fabrication work!!  Looks awesome.  I would like to get better pics of the drivetrain if you could, I am not sure I understand how the rite angle gear box fits in there.  If it is a gear box from a mower deck do you think it will be tough enough to take that kind of hp?
        Pete
  • JDBrian said thank you
#8 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,630 Thanks
  • 5,833 posts
Posted May 31, 2014 - 09:34 AM
I'd assume its set up like that, and using one built for a gokart or high RPM application.
#9 oldmanmopar OFFLINE
oldmanmopar
  • 125 Thanks
  • 83 posts
Posted June 02, 2014 - 11:15 PM
I will get some pics after paint while it is being assembled. Its a little heavy but the weight will be needed. It would have American Racers but . One race calls for Turf tires and another you have to put on  AG tires. Must have the lawn or garden tractor frame any motor is legal.  If you feel comfortable straddling  a V8 you can do it.  This is a bunch of country boys that are getting together to have some fun. There is a dirt oval and then a mud slick trail race with some high speed jumps. I'm sitting on the truck until its over.
  • Texas Deere and Horse and HDWildBill have said thanks
#10 oldmanmopar OFFLINE
oldmanmopar
  • 125 Thanks
  • 83 posts
Posted June 16, 2014 - 08:58 AM
He did some more work on the right angle gear box and. Changed it to 1.5 :1. Its also tore down for welding bead blasting then paint . Shouldn't be long.
  • Alc, HDWildBill, LilysDad and 1 other said thanks
#11 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted June 16, 2014 - 11:18 PM
One word "AWESOME" where in PA do you race? might be worth the drive to watch thanks
#12 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,970 Thanks
  • 9,615 posts
Posted June 17, 2014 - 07:25 AM
That has got to be the cleverest use of a mower deck gear box!
#13 Cvans OFFLINE
  • 6,455 Thanks
  • 6,052 posts
Posted June 17, 2014 - 10:15 AM
Beautiful fabrication work. That little chain and gear box is going to have it's hands full with 100hp.
#14 FrozenInTime OFFLINE
FrozenInTime
  • 649 Thanks
  • 398 posts
Posted June 18, 2014 - 03:53 AM
Looks like fun.  I've seen it on the tele, never in person, would love to.  You can get 100 horses out of a 25 horse eng?  Holly mackerel!!  I had no idea those racers had that much power.
#15 UncleWillie ONLINE
  • 15,518 Thanks
  • 8,704 posts
Posted June 18, 2014 - 11:01 AM
Wow. And here it thought some of the GT pullers were insane.
