Help With A Roto Hoe Tiller
20 replies to this topic
#1 fball1208 OFFLINE
fball1208
  • 1 Thanks
  • 12 posts
Posted May 28, 2014 - 02:53 AM
First off want to say hi from PA. Next i was lucky and got a Roto Hoe 990-4 tiller at auction for 200$. Its in great shape has the 8hp Tech motor. THe problem is it is missing two belts and i have no idea what size they are. The first belt is the one going from teh motor to drive and second is the secondary belt that runs the tines. I am looking for size on the belts and how the secondary is mounted. Thanks for any help
#2 KennyP OFFLINE
  • 31,403 Thanks
  • 41,589 posts
Posted May 28, 2014 - 04:57 AM
:wave: Welcome to the forum! Can't help with your issues. Someone will be along with some help!
#3 Alc OFFLINE
  • 5,936 Thanks
  • 6,893 posts
Posted May 28, 2014 - 05:23 AM
Welcome to GTTalk !  Can't help you with your belt size #s . I have a Roto-Hoe Chipper/Shredder   that needed one of the belts and I couldn't find any info for it , but I think your going to have it a little easier , it seemed like more tiller info was out there . I ended up taking an old belt I had laying around ( I don't throw anything away lol )  that was longer but the correct width , I wrapped it around the pulleys and cut it to length , measured it for size and that worked for me . Good Luck
  • tractorgarden said thank you
#4 GWest OFFLINE
GWest
  • 471 Thanks
  • 426 posts
Posted May 28, 2014 - 12:16 PM
See if this link takes you to a belt chart
http://www.rcweidmar...lts/rotohoe.pdf
Found it with a Google search
Garry
#5 fball1208 OFFLINE
fball1208
  • 1 Thanks
  • 12 posts
Posted May 28, 2014 - 03:16 PM
Thanks gwest but it gave me a 404 error. I'll try again at work tonight see if it will open on a computer
#6 fball1208 OFFLINE
fball1208
  • 1 Thanks
  • 12 posts
Posted May 28, 2014 - 05:40 PM
So found this when I removed the old exhaust today. Do u think I should replace the carb it leave it alone ImageUploadedByTapatalk1401316784.007678.jpg
It's a xut into the wall of the carb
#7 fball1208 OFFLINE
fball1208
  • 1 Thanks
  • 12 posts
Posted May 28, 2014 - 05:49 PM
Looks like previous owner cut possibly an exhaust off as I just turned the one that was on there with a big pipe wrench
#8 olcowhand OFFLINE
  • 36,886 Thanks
  • 30,152 posts
Posted May 28, 2014 - 05:58 PM
If the bowl is still sealing, I'd leave it alone.  The nick in the carb is nothing to worry about.  If it leaks, it'll be because of the bowl nick, or just an old seal ring.  It really just seals at the top & bottom of the rubber ring.
#9 fball1208 OFFLINE
fball1208
  • 1 Thanks
  • 12 posts
Posted May 28, 2014 - 06:25 PM
Ok thanks. Once I get the new exhaust on it run it and see if she leaks
#10 fball1208 OFFLINE
fball1208
  • 1 Thanks
  • 12 posts
Posted May 28, 2014 - 10:19 PM
Also wondering if anyone has information on the snow thrower attachement as i got taht with it also. Thanks
#11 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted May 29, 2014 - 03:01 AM
I have a Roto-Hoe 990-6. Any info on it is VERY hard to find. I have a parts manual somewhere, I'll have to look for it.
I'd like yo see pictures of the Snow Thrower attachment for it.
#12 fball1208 OFFLINE
fball1208
  • 1 Thanks
  • 12 posts
Posted May 29, 2014 - 03:26 AM
When I get a chance I'll take some pics of it. It already got burried in my garage
#13 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted May 29, 2014 - 03:35 AM
Any info on Roto-Hoe is HARD to find. They made at least 2 different tillers. Yours has a 4 speed transmission, mine has a. 6 speed.
The PO converted mine to electric start. There is a manual on-line for it, but that's about all. They also made at least 2 different chippers, a 5hp model and a 8hp model. I have most of a 5hp model, I have yet to find a manual for it.
I'll try to upload the manual this weekend.
#14 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted May 29, 2014 - 03:38 AM
I did upload the Manual it here.
http://gardentractor...and-power-unit/
I thought mine was a 990-6 it's a 990-5. The only difference is the number of speeds in the transmission.
#15 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted May 29, 2014 - 03:43 AM
As far as I know these are the only manuals available.
