Case 155 Hydraulic Problem
9 replies to this topic
#1 anixon92 OFFLINE
anixon92
  • 18 Thanks
  • 51 posts
Posted May 27, 2014 - 05:28 PM
Case 155 i just got it deliver to me.
I changed hydraulic oil and cleaned the screen which was clean. I used rotella 15-40 oil and filled to 2" below plug.  tractor will not move till shift lever is 3/4 forward same goes for reverse. tractor moves very slow forward/reverse in low range and will not drive forward up a little hill in yard. in high range same for shift lever 3/4 but it does go faster, but not like the case 222 that i have had in the pass.
now i don't know any history of 155 besides po brought it to use as a puller and just let it sit in barn for 2 yrs. my son pick it up from po and said po was mowing with it when he got there.
question i have is is there a test port under the valve control to hook up a pressure gauge and what would the pressure be.
also the ignition switch was a toggle switch which i brought a 2 post on/off switch and when i hook the 2 wire termials up to switch. the switch is backwards.
with key off the tractor is on--- key on the tractor shuts off.   i switch the wires on the post and same thing.
does anybody know where i can get a key switch. i know part number is c13985. but i cann't find anything else replaced by 23839 which as alot of post on it, and i only need 2.
any help
thanks
al
Edited by anixon92, May 27, 2014 - 05:33 PM.
#2 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted May 27, 2014 - 06:56 PM
  I have a case 155 here, I am going to watch this post as the hydraulic's on my machine seem a little week as well.  As for the ignition switch, I had to replace mine and I got a new one from tractor supply.  I think it was for an 8n but not sure, it had two wires on it but I took a soldering iron and removed the wires then drilled two holes.  Viola, looks just like the original and only cost $15.  Good luck
        Pete
#3 anixon92 OFFLINE
anixon92
  • 18 Thanks
  • 51 posts
Posted May 27, 2014 - 07:06 PM
i will check tractor supply.
#4 tom tractor ONLINE
tom tractor
  • 235 Thanks
  • 222 posts
Posted May 28, 2014 - 05:00 AM
I am presently replacing my hydraulic drive motor (On my Case 190) because of lack of power issues.  Forward was week and reverse was some what stronger.  The pump has already been replaced along with fluid and cleaning.  I am hoping the hydraulic drive motor makes a big difference.  I have been told it does.  We will see....
#5 anixon92 OFFLINE
anixon92
  • 18 Thanks
  • 51 posts
Posted May 28, 2014 - 05:08 AM
keep me posted on replacing drive motor.  were do you located a drive motor.
#6 tom tractor ONLINE
tom tractor
  • 235 Thanks
  • 222 posts
Posted May 28, 2014 - 05:57 AM
I got mine off ebay from Metro Fluid Power (240$).  Most people get their motor from Motion Industries (300$).  Attached is a list of the correct motors for the early Case's.
#7 Rick OFFLINE
Rick
  • 15 Thanks
  • 168 posts
Posted May 28, 2014 - 09:22 AM
Sounds like your hydro pump is real weak. I had an old 222 do the same thing. I replied the pump and now it's good to go.
#8 tom tractor ONLINE
tom tractor
  • 235 Thanks
  • 222 posts
Posted May 31, 2014 - 01:32 AM
I replaced the hydraulic motor and the 190 has more power forward and reverse is stronger.  I wouldn't say that the tractor is powerful.  12 hp in all.
#9 anixon92 OFFLINE
anixon92
  • 18 Thanks
  • 51 posts
Posted May 31, 2014 - 05:12 AM
i order a new hyd motor.
#10 anixon92 OFFLINE
anixon92
  • 18 Thanks
  • 51 posts
Posted June 05, 2014 - 09:12 PM
$205. for new hydraulic motor. Got it today and install today and tractor runs fine now.  So it was the hyd. motor.
