Bush Hog Rear Axles Comparison
7 replies to this topic
#1 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted May 27, 2014 - 04:33 PM
I have a guy looking for a rear axle for a D4-7 (same as a T-63 axle). I did not have a spare but did notice one of my D4-7 axles may have started its life as an axle for a D4-10 or another GT.
The early model T-63 and D4-7 axles tips can be cracked or broken and are hard to replace.
Note at the bottom of the picture you will see the tip of a screw driver that points to the milled down axle for the D4-7. The two larger diameter axles on left are for the D4-10 tractors. The smaller diameter axles on the right are for the T-63 and D4-7 tractors.ImageUploadedByTapatalk1401226361.898077.jpg ImageUploadedByTapatalk1401226379.702166.jpg ImageUploadedByTapatalk1401226391.990837.jpg
Edited by sacsr, May 27, 2014 - 05:49 PM.
  • DH1, MH81, Alc and 3 others have said thanks
#2 JDBrian OFFLINE
  • 9,599 Thanks
Posted May 28, 2014 - 06:25 AM
That's quite a collection of axles. It doesn't look like the BH tractors used a Peerless rear end. Who made the rear end on those, or did they make them in house?
  • sacsr said thank you
#3 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted May 28, 2014 - 06:38 AM
Brian the transaxles were made "in house". I think they had company's make/caste the parts, but were assembled in the BH factory.
Arrow made the ring and pinion gears (and I think they made gears for the rotary mowers as well). So far we have not found any other make of tractors we can steal parts from for these transaxles.
I should have shown the last two axles on the right are broken/cracked axles. Will take that picture as well.
  • Alc and JDBrian have said thanks
#4 olcowhand ONLINE
  • 38,832 Thanks
  • 30,707 posts
Posted May 28, 2014 - 07:53 AM
Scott, that machined axle should also have a deep woodruff keyway on the side we can't see??  If there isn't the remnants of a keyway, then it would have had to have been done at the factory, before the woodruff slots were cut.
#5 JDBrian OFFLINE
  • 9,599 Thanks
Posted May 28, 2014 - 10:14 AM
That's interesting that they rolled their own transmissions when many major players were using Peerless.
#6 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted May 28, 2014 - 10:29 AM
They did have a series of tractors that came with a peerless transmission and were belt driven.
#7 olcowhand ONLINE
  • 38,832 Thanks
  • 30,707 posts
Posted May 28, 2014 - 10:38 AM
Yes, the V series had a Peerless 2300 series transaxle.  I used parts from a John Deere 110 transaxle to repair my V4-6 transaxle.
#8 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted July 11, 2014 - 09:22 PM
Learned something tonight. I was working on a T-63 rear end and on one side, the bearings were not mating up to the cup- the axle seemed to be hitting something and stopping. Other side worked fine. Pulled the axles to compare and sure enough they were different- not sure which one went to what transaxle since they supposed to be the same- the punch at the bottom points to where the differences are in these axles.
Edited by sacsr, July 12, 2014 - 07:37 AM.
  • olcowhand, DH1, MH81 and 1 other said thanks
