Just Took A Hot Shower
13 replies to this topic
#1 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 27, 2014 - 01:50 PM
I was mowing the barn areas on one of my 2 John Deere F935's.  Lately this one has been getting warm enough the heat light & alarm goes off (radiator was full).  Thinking it was just the radiator fins a bit dirty, I blew it all out good & went to mowing.  About an hour in I'm showered across my back with hot water!  No harm done, but the upper radiator hose blew a rip 5+ inches long & went off like a pistol shot.  Oh well, got the other F935 out & finished the job....after a fresh T-shirt that is.  Now I need to go pull it to the shop.  I figure the thermostat is bad, but I'll test it in boiling water to be sure.
  • hamman, KennyP, sacsr and 5 others have said thanks
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted May 27, 2014 - 02:05 PM
That water is a little hotter than the normal shower, glad your OK
  • bgkid2966 and boyscout862 have said thanks
#3 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 27, 2014 - 03:00 PM
Yep, but not what I was expecting when I realized what had happened.  When it burst, it sent it more like a thick mist instead of globs of hot water.  I guess this means I should fix the hinges on the engine hood & put it back on....reckon?  Was getting ready to tow it to the shop when a thunderstorm rolled in.  Huge drops of COLD rain!  First hot, then a cold shower!
  • KennyP, bgkid2966 and boyscout862 have said thanks
#4 Cvans ONLINE
  • 7,289 Thanks
  • 6,378 posts
Posted May 27, 2014 - 03:06 PM
Glad you weren't burned when the hose ruptured. Nice cool rain sounds good.
#5 grand OFFLINE
grand
  • 2,214 Thanks
  • 2,055 posts
Posted May 27, 2014 - 03:44 PM
Glad you weren't hurt Daniel. Sure sounds like a rather unpleasant surprise.
#6 boyscout862 ONLINE
  • 13,552 Thanks
  • 9,427 posts
Posted May 27, 2014 - 04:17 PM
I am glad that you weren't hurt too. I have found alot of erratic thermostats in the last 15 years. I try to keep using the old ones as long as they are working okay. I find the new defective problem often. I learned to drill a small hole in the thermostats(like they used to come with) to prevent blow back if the thermostat sticks. Good Luck, Rick
  • bgkid2966 said thank you
#7 HDWildBill OFFLINE
  • 8,984 Thanks
Posted May 27, 2014 - 04:29 PM
Glad you weren't hurt.  That could have been bad.  As I read your post the thermostat was the first thing that came to my mind as well.
#8 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 27, 2014 - 04:33 PM
Just need a radiator hose.  I had a known good thermostat from my daughter's car, which I replaced just because I had to take the housing off to get at something else.  It surprised me that it fit!  It's a 195*, so it's perfect.  I'll cut a new gasket.  Taking Teresa out to Famous Recipe for her Birthday (that's today), so hoping I can match a radiator hose at an auto parts store while I'm out.  The original thermostat had a hole with a dangly thing in it, so I had intended to drill a little hole in this one.
  • KennyP, sacsr, HDWildBill and 1 other said thanks
#9 KennyP ONLINE
  • 40,911 Thanks
  • 47,110 posts
Posted May 27, 2014 - 05:59 PM
HAPPY BIRTHDAY, TERESA!!!!!!!!!!!!
Glad you weren't hurt and have an easy fix going!
  • olcowhand and bgkid2966 have said thanks
#10 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 27, 2014 - 06:31 PM
The auto parts was closed, but that's ok as I have backup mowers.  Man am I stuffed!  The food at Famous Recipe was great!  Now to just relax!
  • KennyP, Cvans and bgkid2966 have said thanks
#11 KennyP ONLINE
  • 40,911 Thanks
  • 47,110 posts
Posted May 27, 2014 - 07:16 PM
I'm stuffed too! Just did seconds on yesterdays ribs and brisket!
#12 MH81 OFFLINE
  • 29,978 Thanks
Posted May 27, 2014 - 07:25 PM
Sounds like the last time I thought I was going to have some alone time with the Mrs...
  • olcowhand, DougT, Texas Deere and Horse and 1 other said thanks
#13 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted May 28, 2014 - 11:51 AM
I think I better take the "fifth" on this or there might be a lot more of those cold showers ahead !
Daniel sure glad you weren't hurt, that could have been really BAD....
#14 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 28, 2014 - 11:57 AM
Matched up a hose locally, cut off the excess, installed, and just mowed up & down the roadside.  She was unharmed and running great!
