Holy Cow, I Forgot How Much Jd Parts Were..
7 replies to this topic
#1 Kentucky OFFLINE
Kentucky
  • 106 Thanks
  • 62 posts
Posted May 27, 2014 - 01:00 PM
I haven't bought a JD part in a long time. I need to get the brakes changed in my gt262. They are wet disc brakes..Two plates and a disc kit, $300 for the parts alone :wallbanging:  Holy crap, I forgot about the green=Gold equation.
#2 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,134 Thanks
  • 10,203 posts
Posted May 27, 2014 - 01:03 PM
Right up there with Harley stuff, eh?
#3 Kentucky OFFLINE
Kentucky
  • 106 Thanks
  • 62 posts
Posted May 27, 2014 - 01:07 PM
Yea, really. three little composite discs and two small metal discs..Im shocked honestly, even for JD that seems high.
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 27, 2014 - 01:22 PM
Anything aftermarket available?
  • Kentucky said thank you
#5 Kentucky OFFLINE
Kentucky
  • 106 Thanks
  • 62 posts
Posted May 27, 2014 - 01:52 PM
No luck yet, its the tuff-torq 6-speed. If anyones knows of a cheaper option id sure like to know :thumbs:
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 28, 2014 - 06:33 AM
Did anyone else use that transmission in their tractors. If so, you may be able to get the parts from them.  I don't know if you can source tuff torq parts directly or not. The other option would be to check with JD recyclers for used parts or even a transmission may be less than 300. The parts tend to get more expensive every year for the older tractors. For routine maintenance parts I find the JD dealer is competetive.
#7 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted June 01, 2014 - 07:08 AM
Don't feel bad - it's not just John Deere! I am restoring an old 73 Kawasaki H2 motorcycle, and some of the parts (from the dealer) for that were shockers as well. They wanted $60.00+ for what amounts to 2 flat washers and a couple spring circlips. I made the washers myself from flat stock and second sourced the clips for a couple bucks!
Check aftermarket for your parts or see if there is a vendor for tuff torque parts - I had a similar problem with a craftsman transaxle and leaking seals. Got them mailorder from the internet for 1/3 of what sears wanted for them...
#8 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,165 Thanks
  • 1,332 posts
Posted June 01, 2014 - 01:42 PM
Well at least
Well at least you can still get new parts for your Kawasaki.  I am restoring a 1966 Honda Scrambler for an old customer and the carb slides were frozen in.  Both the bore and slide are completely shot.  I found a couple of online sites that say they can get the carbs for around $150 each but when I email or call them to insure they are available I am told they will check but so far no call backs..The front brake cable was the same way, I could get one for the lower style handlebars but for the optional high rise bars Nope.  Ended up going to the machine shop and he fabricated a barrel end on it.
Edited by GTTinkerer, June 01, 2014 - 01:44 PM.
