What Is This?
9 replies to this topic
#1 cglisson01 OFFLINE
cglisson01
  • 261 Thanks
  • 151 posts
Posted May 27, 2014 - 10:39 AM
Found this old cast iron piece that is labeled as a motor adjuster. But I dont know if that is what it is for sure or not. Has anyone else ever seen one?
#2 TAHOE ONLINE
TAHOE
  • 6,731 Thanks
  • 5,089 posts
Posted May 27, 2014 - 11:09 AM
We have those types on our big mixers here at work, although newer and just big jack scerws used for adjustments. Ours are used to tighten the 4" wide cog belts between the motors and mixers.
That's obviously off somthing much smaller, but probably same principle
  • Texas Deere and Horse, boyscout862, superaben and 1 other said thanks
#3 cglisson01 OFFLINE
cglisson01
  • 261 Thanks
  • 151 posts
Posted May 27, 2014 - 11:18 AM
o ok. That makes sense. I was thinking it would be neat to mount a small briggs on it and use it to engage a corn grinder or water pump or something
Edited by cglisson01, May 27, 2014 - 11:19 AM.
#4 TAHOE ONLINE
TAHOE
  • 6,731 Thanks
  • 5,089 posts
Posted May 27, 2014 - 11:39 AM
That might work like that since that one is spring loaded. Ours at work are all fixed and mainly for tightening belt in stationary position, only used when changing belts.
  • cglisson01 said thank you
#5 Traill95 ONLINE
Traill95
    Traill95
  • 1,657 Thanks
  • 951 posts
Posted May 27, 2014 - 08:41 PM
What he said. We have them at work to tighten belts on blowers. the motor mounts on them.
Edited by Traill95, May 27, 2014 - 08:42 PM.
#6 cglisson01 OFFLINE
cglisson01
  • 261 Thanks
  • 151 posts
Posted May 27, 2014 - 09:40 PM
I ended up purchasing it. When I got it home and got it all cleaned and freed up, I mounted a briggs 5s motor on it. It turned out looking pretty good. I'll post some pictures later if I get a chance
  • Texas Deere and Horse and IamSherwood have said thanks
#7 IamSherwood OFFLINE
  • 8,381 Thanks
  • 7,696 posts
Posted May 27, 2014 - 10:16 PM
If you don't find a use for it, you could mount a clock on it.
Seriously.
Edited by IamSherwood, May 27, 2014 - 10:17 PM.
#8 DougT ONLINE
DougT
    Dog Approved
  • 6,042 Thanks
  • 4,447 posts
Posted May 27, 2014 - 11:44 PM
Seriously.
I like that idea. Take the flywheel off the 5s and put the shroud with the clock on it.
#9 LilysDad ONLINE
LilysDad
    Crazy about GTTalk
  • 10,471 Thanks
  • 8,108 posts
Posted May 28, 2014 - 06:38 AM
I saw one like that on a small metal lathe. It had a Reeves(spring loaded) split pulley on the electric motor. By cranking it, pulling the motor against the pulley, it changed the speed of the lathe.
Edited by LilysDad, May 28, 2014 - 06:39 AM.
#10 cglisson01 OFFLINE
cglisson01
  • 261 Thanks
  • 151 posts
Posted May 28, 2014 - 07:43 AM
Seriously.
Y'all might be on to something there lol. I've already got 7 shroud clocks to build for some guys who ordered them from me
