Here's Something To Ponder For A Bit!
toro 322d mitsubishi k3d diesel starting by itself
43 replies to this topic
#31 KennyP OFFLINE
  • 40,128 Thanks
  • 46,764 posts
Posted May 29, 2014 - 06:27 AM
Yeah, the "control unit" is some type of module. Not sure of it's complete purpose. I'll look into things this weekend, just too wore out when I get home. If the seat switch does work, I think tying it into the solenoid wire would stop any 'self-starting' issues.
I want to see where the A & B is going to at the moment. According to that diagram, I am unsure which wire is power to the switch, may be X.
#32 MH81 OFFLINE
Posted May 29, 2014 - 06:47 AM
If you use the seat switch for outside the intended purpose, two things come to mind:
One, the seat switch may not have enough current carry for the solenoid
Two, if it does, you will not want to use the original wires at all. Just add two new ones that put it inline on the solenoid wire.
#33 KennyP OFFLINE
  • 40,128 Thanks
  • 46,764 posts
Posted May 29, 2014 - 05:36 PM
I can't say what is going to the solenoid, so I'll keep this in mind when I get to it Alan!
#34 toppop52 OFFLINE
toppop52
  • 5,456 Thanks
  • 4,863 posts
Posted May 29, 2014 - 06:59 PM
If you've ever seen the movie, Maximum Overdrive...
#35 KennyP OFFLINE
  • 40,128 Thanks
  • 46,764 posts
Posted May 30, 2014 - 04:24 AM
Nope!
#36 toppop52 OFFLINE
toppop52
  • 5,456 Thanks
  • 4,863 posts
Posted May 30, 2014 - 05:38 PM
Machines come to life, trucks, tractors and cars all running on their own as if they were alive.
#37 KennyP OFFLINE
  • 40,128 Thanks
  • 46,764 posts
Posted May 30, 2014 - 06:34 PM
I had an easier day so I hooked the battery back up & fired it off. Other than a BIG could of smoke and the alternator working overtime, all is well! I still plan to get something figured out so it doesn't do it again!
#38 UncleWillie OFFLINE
  • 16,105 Thanks
  • 8,906 posts
Posted May 30, 2014 - 06:55 PM
A battery disconnect is cheap and easy.
#39 KennyP OFFLINE
  • 40,128 Thanks
  • 46,764 posts
Posted May 30, 2014 - 07:18 PM
Just where to put it to be easy to use is the next question!
#40 KennyP OFFLINE
  • 40,128 Thanks
  • 46,764 posts
Posted May 31, 2014 - 05:52 PM
Got into the wiring today! The circuit for the seat switch, etc. had been jumpered. I wired in the seat switch and you have to sit in it before the starter will work!
  • olcowhand and MH81 have said thanks
#41 toppop52 OFFLINE
toppop52
  • 5,456 Thanks
  • 4,863 posts
Posted June 01, 2014 - 10:51 AM
Bah, safety switches take all the excitement out of it! :smilewink:
#42 Boss 448 OFFLINE
Boss 448
  • 48 Thanks
  • 248 posts
Posted June 18, 2014 - 04:19 PM
I imagine that if you check you will find that this is covered under one of the many recent GM recalls. They're issuing recalls for everything else. :bigrofl:
JN
#43 KennyP OFFLINE
  • 40,128 Thanks
  • 46,764 posts
Posted July 10, 2014 - 06:34 PM
Guess it's time go for the battery disconnect as it did it again. The seat was in the propped up position, so it's not in the switch. Something is getting power to the solenoid during a hard rain.
  • olcowhand said thank you
#44 KennyP OFFLINE
  • 40,128 Thanks
  • 46,764 posts
Posted July 14, 2014 - 06:06 AM
Decided to try something different. The solenoid wire is a spade connector on the starter, so I am just going to unhook it for now to see if it tries this again.
Also tagged with one or more of these keywords: toro 322d, mitsubishi k3d, diesel starting by itself
