Wanted
Briggs Carb #391065
4 replies to this topic
#1 Bloodyknuckles OFFLINE
Bloodyknuckles
  • 24 Thanks
  • 22 posts
Posted May 26, 2014 - 12:47 PM
Fits a 1972 MTD 990 with a 15hp B&S engine. Need just the bottom half but will buy the whole carb if need be. Same thing Roger was looking for. Thanks.
Bloodyknuckles
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 26, 2014 - 02:44 PM
For those looking in, he needs the lower half of a large 4 bolt two piece Flo-Jet.
I do have one complete carb here.  PM me if you are interested.
Ben W.
  • Bloodyknuckles said thank you
#3 Bloodyknuckles OFFLINE
Bloodyknuckles
  • 24 Thanks
  • 22 posts
Posted May 31, 2014 - 07:19 PM
The local John Deere dealer was able to retap the hole for $3.00. The emulsion tube was a little tight getting it in. The main needle valve went right in. Hope it works.
Bloodyknuckles
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 31, 2014 - 08:18 PM
Did you put in a new teflon sealing washer behind that nozzle?  That will help ward off leaks if that sealing surface is warped.
Your JD dealer must be a good group.  Mine would have charged the minimum shop rate of $50.  :wallbanging:
Ben W.
#5 Bloodyknuckles OFFLINE
Bloodyknuckles
  • 24 Thanks
  • 22 posts
Posted June 01, 2014 - 09:42 AM
I used the seal that came with the kit. I don't believe it was teflon though. It looked like thick gasket material. I got lucky with the JD dealer. The mechanic asked me want I wanted and he did the retap right there. No paper work or anything.
