Hvlp Paint Gun
2 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,346 Thanks
  • 9,800 posts
Posted May 26, 2014 - 10:41 AM
I've always used a syphon paint gun before. Now I have a small hvlp. What is the difference in the paint / thinner mixing ratio?
#2 glgrumpy ONLINE
  • 8,622 Thanks
  • 7,926 posts
Posted May 26, 2014 - 11:20 AM
Only HVLP I have seen that is much diff is those kind that use a Vacumn cleaner like motor, have big hose to gun and use little pressure at all. Eastwood pushes those.  I think the HVLP gun you still use on your compressor has mix about same as any. Maybe I'm wrong, but this was my observation. Just the pressure needed is lower at working end.
  • LilysDad said thank you
#3 case1man OFFLINE
case1man
  • 189 Thanks
  • 135 posts
Posted May 26, 2014 - 01:14 PM
Paint will mix the same and on some guns you can turn up the air pressure and it will spray like a regular gun
