Using The Hillers On The Db
39 replies to this topic
#31 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted June 14, 2014 - 07:09 AM
I want to make a couple showing the garden seeder vs. the field planter too.
  • trowel said thank you
#32 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 14, 2014 - 07:13 AM
I don't recall any vidios out there of the seeder drill or planter so please do and mabey a brief tutorial of each before and after use would be great.
  • VSTROM803 said thank you
#33 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted June 14, 2014 - 03:54 PM
O.K. I posted a new topic in the implement forum. ALC mentioned pinning it in the walk behind forum but, I don't know how to do that.
http://gardentractor...-field-planter/
#34 Alc ONLINE
  • 7,349 Thanks
  • 7,634 posts
Posted June 15, 2014 - 07:12 PM
Mounted the hilling sweeps fromt eh Tri-Trac on the 600's shanks , didn't do much better , tried mounting  another set of hilling sweeps  in front of them ,that was just a little better. Maybe hilling discs would work on a walk behind ?
Edited by Alc, June 15, 2014 - 07:16 PM.
#35 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 15, 2014 - 08:57 PM
Moderators can do that.
Worth a shot, i hope it works.
#36 MH81 OFFLINE
  • 29,979 Thanks
Posted June 16, 2014 - 04:47 PM
I'm sure they would, but you might try resetting the sweeps.
My limited experience is that you need a lot of overlap to get a cumulative effect unless they are the big ones.
Empire made the ones on our planter/ hiller. It works great.
#37 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 16, 2014 - 05:14 PM
well one could go old school and use a set of disc gangs like a Handiman There were a limited amount of companies that made disc setups for hilling. seems to me there were 3 disc units for the Simplicity walkers, that fit on a cultivator bar, and I'm sure Bolens had something similar.
#38 Alc ONLINE
  • 7,349 Thanks
  • 7,634 posts
Posted June 17, 2014 - 05:45 AM
Last night I searched for disc hiller for walk behind and found a few out there . I will try over lapping , or make extensions like on the Troy Bilt furrower  . I have one of these and the extensions are only heavy gauge sheet metal .  Guess once the dirt is loose it doesn't need to be very thick or harden steel to form it up around the plants
#39 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 24, 2014 - 09:31 AM
When I had the Gilson rear tine tiller, it had a sweep just like a middle buster sweep only about 8-10 inches.
It worked pretty well by running between the rows an pushing the soil up on each side.
It was probably one of the best features on that tiller.
I could never hold bearings in the speed control group. I finally junked it after having to rebuild that every year I owned it.
#40 Alc ONLINE
  • 7,349 Thanks
  • 7,634 posts
Posted June 24, 2014 - 10:37 AM
I didn't leave enough space between the rows but that's a good idea for next year :thumbs:
