How To Fix This?
13 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 25, 2014 - 08:25 PM
I want to peel the protective paper off these aluminum blanks on my radio. I don't want to scar the alum. The paper is brittle.
  • hamman and toomanytoys84 have said thanks
#2 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 25, 2014 - 08:29 PM
I think I've posted this before....my grandfather built this back in the 60s. Hand built and designed all the circuitry. Brilliant man. He was the head chemist at Kodak.
Cost on the speakers(I think)
Edited by Texas Deere and Horse, May 25, 2014 - 09:02 PM.
Rotated photos
  • MH81, hamman, sacsr and 4 others have said thanks
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 25, 2014 - 08:30 PM
Tubes and amps everywhere... still sounds great.
  • hamman, bgkid2966, LilysDad and 2 others have said thanks
#4 lyall ONLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted May 25, 2014 - 08:45 PM
try goo-gone
it may work
  • Alc and BairleaFarm have said thanks
#5 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted May 25, 2014 - 08:51 PM
Heat gun and plastic scraper maybe.
  • BairleaFarm said thank you
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 25, 2014 - 08:55 PM
As brittle as it is I wonder if just water would work? I just don't want run marks.
Sent from my SAMSUNG-SGH-I437P using Tapatalk
#7 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted May 25, 2014 - 09:03 PM
Try denatured alcohol.
  • Cat385B and BairleaFarm have said thanks
#8 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted May 26, 2014 - 05:29 AM
I'd go gentle, start with soap and water, then go to alcohol. It looks like those are standard rack panels and as such you can still buy them from companies like Hammond which may very well be the brand of the rack. They have been in business a long time. I have a tube amp I built from scratch in 2001. I was in the last class to learn tube theory at my trade school in 1980 and I used that knowledge at work to repair tube powered gear until about 5 years ago when the last of it was retired. Well designed tube gear is pretty reliable, and pretty much all audio tubes are still available although they are a lot more expensive then they were even 10 years ago. Can you post a picture of the speakers and tell us a bit more about the configuration of the setup? Mono or stereo amps, etc.
#9 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 26, 2014 - 03:55 PM
My biggest problem is this stuff is more advanced than I am. I know the stuff needs some work. Luckily it's all been stored inside. I just tried it and something isn't working. I know the capacitors should be replaced but at this time I'm hesitant to get into it. Here's what I think everything is...
A Fisher tuner
  • toomanytoys84 said thank you
#10 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 26, 2014 - 03:56 PM
Then to the preamps. He color coded and labeled most of it.
#11 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 26, 2014 - 03:57 PM
Don't forget the power supplies. Everything has a left and a right.
#12 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 26, 2014 - 03:59 PM
The amps...two for each side. I would assume each side has a output for the speakers I have and the sub woofers that are at my parents.
#13 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 26, 2014 - 04:01 PM
The speakers...
#14 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,107 Thanks
  • 6,470 posts
Posted May 29, 2014 - 07:25 PM
Very smart man. I could never build that. Don't have any suggestions but thank you for sharing that.
