Cleaning The Tractor After Mowing
11 replies to this topic
#1 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted May 25, 2014 - 07:29 PM
This is what I use to clean the grass off the tractor when I finish cutting the grass.
I leave the engine running, 1/2 throttle and use 1 off these 2 blowers, you can even clean out the engine cooling fins by forcing more air in both ways. As many different directions as I can.
Fast, easy, and it works with wet grass just takes longer.
  • MH81, Alc, IamSherwood and 6 others have said thanks
#2 JDBrian OFFLINE
  • 9,601 Thanks
Posted May 25, 2014 - 07:40 PM
Great idea and doesn't get everything soaked!
  • Gabriel said thank you
#3 KennyP ONLINE
  • 37,388 Thanks
  • 45,444 posts
Hadn't thought about using those!
#4 lyall OFFLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
Posted May 25, 2014 - 08:48 PM
I have used my gas blower or my air compressor
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,777 Thanks
  • 9,918 posts
Posted May 25, 2014 - 09:21 PM
Air compressor for me.
#6 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,792 posts
Posted May 25, 2014 - 09:24 PM
2nd that. Although, I may try the leaf blower since I have it out afterwards anyways.
Eric
Sent from my EVO using Tapatalk
#7 IamSherwood OFFLINE
  • 8,390 Thanks
Posted May 25, 2014 - 09:33 PM
Good idea. Another reason for another tool, for the arsenal.
#8 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted May 25, 2014 - 09:38 PM
Have always used the air compressor. Thanks for the blower idea.
#9 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted May 25, 2014 - 09:48 PM
Lead blower is the handiest tools if you have a shallow crick start the mower with the deck up and slowly drive into it clean the deck great but it dont take much casue the water is sucked up
#10 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
We're supposed to Clean them?  Once in awhile I hit it with a hose, and have used compressor at times. As to under the deck the grass dries and falls out in big chunks after a mow or two, heh!   I know, acid eating paint and metal not good. When it rusts thru, get new mower then!
#11 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted May 26, 2014 - 06:54 AM
:ditto:    :iagree:
#12 HDWildBill ONLINE
  • 8,975 Thanks
Posted May 26, 2014 - 10:30 AM
Shop air here as well.
