Need Help Mounting My Mower Deck
25 replies to this topic
#1 aws lude OFFLINE
aws lude
  • 17 Thanks
  • 21 posts
Posted May 25, 2014 - 11:43 AM
Plz help pics work best I have to instructions from.sonnys but I need to see.pics. I can read and read all day but with some.clear pics of what I'm doin it won't help. I have a bolens 1220 and I have a 42 side discharge deck with two green arm to mount it some how. I'm going to have to fab up.some pieces that's fine I can do that just need to know what they are. I borrowed a friends deck but it has a totally different set up it all black deck with springs mounted at front and a lot of arms on it. So if u have a second to take a few pics I would really appreciate it. My gf has been ripping my head off to cut the grass to been months I keep telling her soon as the Bolens is ready Lololol if it ever happens hahahah Thax guys
#2 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted May 25, 2014 - 12:20 PM
Do you have the model number of the mower deck? That would be a BIG help to us. That way we know your configuration.
#3 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 25, 2014 - 03:28 PM
If its the "old style" with the two drag links in the rear, here you go:
the two drag links  run from the rear axle tabs of the tractor to the tabs in the rear of the deck, esentially giving you 4 mounting points
If you need more info let me know.
  • MyBolens1053 said thank you
#4 aws lude OFFLINE
aws lude
  • 17 Thanks
  • 21 posts
Posted May 25, 2014 - 04:44 PM
This is my mower deck i just bought for 200$ but now I have a complete collection snowblower tillers snow blade and mower deck
#5 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 25, 2014 - 04:54 PM
You have everything but the rear drag links
If you have these pictured below you can get that deck on there
#6 aws lude OFFLINE
aws lude
  • 17 Thanks
  • 21 posts
Posted May 25, 2014 - 05:46 PM
I only have one of these so if I'm correct all I need to to fab up the other side and some of those link bars u just posted and it should hook up???
#7 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 25, 2014 - 06:06 PM
Yes, these only had 4 mounting points on the deck.
Its probably going to be easier to buy used ones on ebay..... They are quite easy to find
#8 aws lude OFFLINE
aws lude
  • 17 Thanks
  • 21 posts
Posted May 25, 2014 - 10:56 PM
Does anyone have any extra mounting brackets lol what do they usually go for....my gf is going o kill me when I tell her I can't cut the grass yet lol oh no lolololololol
#9 aws lude OFFLINE
aws lude
  • 17 Thanks
  • 21 posts
Posted May 26, 2014 - 12:02 AM
Hold.on a sec.... i just had a.lght bulb click on if I take a u bolt and cut it in half I would have the link bars....all I would have to.do is make the ends which shouldn't be that hard. can someone plz take some measurements on how long the parts are.on there machine and post them I would be so great full thax
#10 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
Posted May 26, 2014 - 12:17 AM
Hand your girl a weed eater and tell her "You'll catch up when you finish mounting the mower deck."  :poke:
#11 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 26, 2014 - 06:05 PM
Can someone get measurements of those deck links?
All mine are stowed away and I would basically have to clear the garage to get to them
#12 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted May 26, 2014 - 08:10 PM
I think I can find some to measure tomorrow. I'm not exactly sure where they are, but I have a pretty good idea.
Bob
#13 aws lude OFFLINE
aws lude
  • 17 Thanks
  • 21 posts
Posted May 27, 2014 - 10:35 AM
Well got all the pieces now soon as bob posts those numbers I can trim the pieces down to size then cut grass so exciting been almost six months without a mower thax bob can't wait!!!!:)
#14 aws lude OFFLINE
aws lude
  • 17 Thanks
  • 21 posts
Posted May 27, 2014 - 05:58 PM
If anyone needs a new set when.im done I would happly make them a set
#15 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted May 27, 2014 - 06:44 PM
Here are the two I have.
The rods are 5/8" diameter, 11" overall length from end to the center of the "L" end. The threaded portion is 2 1/2" long.
The "L" is 2 3/4" from center to end. The two holes are 7/8" apart, and the outer is about 1/4" from the end. They appear to be for 1/8" pins.
One assembly was 12 1/4" from center to center, and the other was 12 7/16"
Hope this helps, let me know if you need anything else.
Bob
  • Bolens 1000 and MyBolens1053 have said thanks
