Wanted
Looking For Mitsubishi K3B Engine Or Equivalent
satoh s470 mitsubishi s470 sato buck k3b mitsubishi k3b
10 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted May 24, 2014 - 11:38 AM
I'm looking seriously at buying a Satoh/Mitsubishi S470 "Buck" Tractor with a FEL, backhoe, box scraper and rock rake. The price is very cheap.  Only problem is the engine is starting to knock. Parts are readily available, but the wife doesn't want me to get tied up in another long-term project (Gee--I don't understand why she would feel that way!!???).
So rather than rebuild the engine, I'm looking for a good runner that will fit in it.
I understand that the Mitsi K3As are the same block and can be used though they're less hp. I have a source for them, but don't want to use it unless I can easily tweak the fuel system and get some more hp from it.
I know the same engine was used in the Bolens HDT1000, and some of the Iseki-Bolens tractors IIRC.  Toro also used K3-series engines in their mowers--the 325D is one that comes to mind.
So, I need to find a price on a good running K3B, or any of the newer K3-series engines if they will work without major modification--I don't mind swapping out bell housings, etc.
Please let me now what you have and what you want for it.
Regards,
Smitty
#2 KennyP OFFLINE
  • 37,526 Thanks
  • 45,518 posts
Posted May 24, 2014 - 01:24 PM
The Toro GroundsMaster 322-D used the K3-D engine!
  • OldBuzzard and Utah Smitty have said thanks
#3 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted May 24, 2014 - 04:32 PM
Didn't take long for Kenny to pop up with that information. The people on here are great!
#4 OldBuzzard ONLINE
OldBuzzard
  • 6,987 Thanks
  • 4,784 posts
Posted May 24, 2014 - 06:23 PM
The GroundsMaster 325-D used the K3D engine as well.
Also, if I'm not mistaken, the Case/IH 234, 235, 245, 255, and 275 all used K3x engines.
From what I can gather, the K3x engines ranged from the 0.773L K3A rated at 15 hp. to the 1.496L K3M rated at 30 hp.
K3A - 0.773L - 15hp
K3B - 0.847L - 17hp
K3C - 0.899L - 18.5hp
K3D - 0.978L - 22hp
K3E - 1.061L - 24hp
K3F - 1.117L - 25hp
K3G - 1.235L - 23hp
K3H - 1.289L - 25hp
K3M - 1.496 - 30hp
Edited by OldBuzzard, May 24, 2014 - 07:39 PM.
  • Texas Deere and Horse, Cvans and Utah Smitty have said thanks
#5 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted May 24, 2014 - 11:10 PM
Yes Indeed!!
Smitty
#6 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted May 24, 2014 - 11:16 PM
Yep... I knew your mower had a K3 series engine, just couldn't remember what the mower model number was.  A friend here local has a K3D out of a Toro 325, but it's been sitting uncovered behind his house for at least 3 years, so I'm not really confident it will run without some major work...
K3A - 0.773L - 15hp
K3B - 0.847L - 17hp
K3D - 0.978L - 22hp
K3E - 1.061L - 24hp
K3F - 1.117L - 25hp
K3G - 1.235L - 23hp
K3H - 1.289L - 25hp
K3M - 1.496 - 30hp
Good info to tuck away, OB... What I'd like to find out is if any of the larger K3s will bolt up in place of a K3B... I did get a parts manual for the K3A, K3B and K3C, and many part interchange, but there are also several engine configurations in each series, so it's possible even another K3B might not fit due to lack of mounting flanges for the front of the tractor, etc... I'll just need to continue research it...
Thanks,
Smitty
Edited by Utah Smitty, May 24, 2014 - 11:19 PM.
#7 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted May 25, 2014 - 11:41 AM
I wouldn't hesitate to take a closer look at that engine. I don't know which way the intake and exhaust ports are facing but if it isn't stuck it might be worth trying to get running.
#8 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted May 25, 2014 - 02:15 PM
Thanks, Chris... I'll have to take a close look.  I only wish the tractor was here so I could put the two side by side to see if it will swap in.
Smitty
  • Cvans said thank you
#9 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted May 27, 2014 - 08:27 AM
Talked with Bill Rogers at Valley Power Equipment. He has a good stock of Mitsubishi parts--both domestic and brey market, and is very knowledgeable--also very friendly and helpful.
Bill says that the K3C engine will also work, but isn't sure about the K3D or -E.
Smitty
#10 ecoman 79 OFFLINE
ecoman 79
  • 1 posts
Posted November 22, 2014 - 11:45 PM
Hi everyone. I just bought a tractor case ih 235 with a K3B engine on it .the engine was taken apart by the previous owner and there are a lot of missing parts like rod pushers, rocker saft, rock arms...exaust ,air cleaner assy,glow plugs,valve cover ,fuel lines between the pump and the injectors and may be more .I am lookimg for an engine K3B  even if is not in working condition .If somebody has one ,please let me know.thank you .
#11 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted December 17, 2014 - 11:55 PM
I have a K3B or K3C complete that came out of a mower--it's been sitting for a couple years, but still cranks all the way around.  It includes the aircleaner, starter, etc. It belongs to a friend so I'd have to check on the price, but I suspect it would be around $600-$700.
Let me know if you're interested, I'll PM some pictures.
Also tagged with one or more of these keywords: wanted, satoh s470, mitsubishi s470, sato buck, k3b, mitsubishi k3b
