Over Built?
1 reply to this topic
#1 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,102 Thanks
  • 10,172 posts
Posted May 24, 2014 - 09:28 AM
It wouldn't let me post the photo.http://antiquetracto....php?f=35&t=833
Homemade 2 wheel tractor
icon_post_target.gifby MECK » Mon Mar 26, 2012 5:54 pm
I really enjoy seeing the things that you all have come up with and built so decided to show one of my contraptions. Here's a two-wheeled tractor that I made several years ago, named "Rube" for Rube Goldberg. I don't have a good picture from the side that would show the mechanics better, but power went through a triple pulley to a three-speed transmission from a 4wd Chevy Blazer. The rear of the tranny was attached directly to the input of a gear reduction box from a David Bradley two-wheeled tractor that had been turned sideways. The axle shafts from the DB box were cut off and the one running toward the front of the tractor was mated to a cutdown rearend from a '75 Chevy Nova that had been turned backwards. By turning the brake backing plates backwards on the Nova rearend, I was able to use the emergency brake cables to rig up independent brakes. First gear reduction was around 100:1. With antifreeze loaded in the 14" tractor tires, it was practically unstoppable. I used it primarily for pulling a cart built just for the tractor with a seat on it and an articulated hitch to keep the unit together. I disassembled Rube later to use some of the parts in other projects.
  • sacsr, tinbender7 and js5020 have said thanks
#2 js5020 OFFLINE
js5020
  • 711 Thanks
  • 807 posts
Posted May 25, 2014 - 08:02 AM
Over built  :rocker2: ??? Is there such a thing?
