More Hillbilly Engineering
31 replies to this topic
#16 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted May 24, 2014 - 06:31 AM
Where are you going to mount your jack?
  • David Brown said thank you
#17 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 24, 2014 - 06:50 AM
It's a nice bit of insurance to have a spare on board. If you don't you may have to leave your trailer and load on the side of the road while you go get a tire repaired. Not something I'd want to do. I like Olddeeres suggestion to support the tire from the bottom. That would cut down on the movement of the wheel and place the weight in closer to the welds which would reduce stress on them.
#18 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 24, 2014 - 06:56 AM
I carry a small jack in the box.  Pretty compact but it is enough to get the wheel off the ground.
#19 KennyP ONLINE
  • 40,190 Thanks
  • 46,794 posts
Posted May 24, 2014 - 07:54 AM
Every time I need a spare that is held up with a cable mechanism, it is rusted solid.
We are in the road salt capital of the world and it does do a number on those units... One time I had to take a car to the garage for them to get the spare out so I could work on the leaking gas tank. With the leaks, I didnt want to run the grinder or torch to cut the cable.
If I do this, the whole mechanism will get plenty of anti-seize! We don't have the salt issues down here and the trailer doesn't move in those conditions anyway!
  • MH81 and David Brown have said thanks
#20 olcowhand ONLINE
  • 42,453 Thanks
  • 31,824 posts
Posted May 24, 2014 - 07:58 AM
When I built my smaller tilt trailer (5 1/2 x 9), the axle came from a Chrysler minivan.  The axle stubs bolt to the axle beam.  So I went to a junkyard, bought a spare stub complete with hub, and bolted the stub to the trailer side.  If I have a blowout, there is a spare, PLUS, if I blow a bearing, I can unbolt the stub & swap out the whole assembly.
  • MH81, KennyP, sacsr and 3 others have said thanks
#21 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 13,896 Thanks
  • 10,057 posts
Posted May 24, 2014 - 08:20 AM
I was at Walmart and noticed they had dumb bells with the spin on retainers for $7. These would save on fabricating some of your parts.
"Every time I need a spare that is held up with a cable mechanism, it is rusted solid."
The older pick ups had under box spares held up with a threaded retainer that could be locked with a padlock. The padlock is very likely to rust up.
  • MH81, KennyP and David Brown have said thanks
#22 pharmer ONLINE
pharmer
  • 881 Thanks
  • 780 posts
Posted May 24, 2014 - 08:27 AM
Jethro wants you to make him a cement pond now that he knows you do quality work.
#23 Cvans OFFLINE
  • 7,117 Thanks
  • 6,302 posts
Posted May 24, 2014 - 08:31 AM
I was in Walmart and noticed they had dumb bells in the clothing department. Thought it a bit odd until I realized I was standing in front of a mirror.  :smilewink:
  • KennyP, sacsr, David Brown and 1 other said thanks
#24 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 24, 2014 - 09:13 AM
Well I was in WalMart the other day and noticed they had dumb bells behind the counter, in front of the counter, wondering the isles, oh, and me too.
  • Cvans said thank you
#25 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 24, 2014 - 09:19 AM
Yeah, he stopped by and axed for a quote.  I told him I wanted two gallons of his best shine, the daughter that has the most teeth and a good opossum.  He said I could have everything but his supper.  He didn't specify which was which.  I did lend him my mixer though.  Now all he needs is some of that there electrical current.
  • pharmer, sacsr and LilysDad have said thanks
#26 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,034 Thanks
  • 5,985 posts
Posted May 24, 2014 - 10:12 AM
I wouldn't call that hillbilly engineering. That looks professional.
Hillbilly would be tieing it in with an old coat hanger!
Don't forget the duck tape too!!
#27 MH81 OFFLINE
That sounds like it has a back story...
  • KennyP and David Brown have said thanks
#28 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 13,896 Thanks
  • 10,057 posts
Posted May 24, 2014 - 10:16 AM
You'd be fun to go to an auction with!
#29 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 24, 2014 - 11:48 AM
More like a back woods story.
#30 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 26, 2014 - 02:36 PM
Well, the good news of the day is, I took the trailer over to pick up a little Allis and the spare tire made it all the way there and home without moving.  So far, so good.
  • MH81 and Sawdust have said thanks
