For Sale
Kt 17 Twin Parts, Blown Engine
4 replies to this topic
#1 glgrumpy OFFLINE
  • 8,621 Thanks
  • 7,926 posts
Posted May 23, 2014 - 06:50 AM
These engines always blow and now I have one. Was on the Wheelhorse. Block has two holes in it, and inner damage from parts, Cylinders have chunk out bottom edge. DO have valves, cam and lifters, flywheel, main bearings look good, One piston and rod not too bad, that one has just a little heated area on big end of rod. Standard size piston. Other piston not so good, and rod gone for sure. Carb and intake OK, Crankcase bolts and nuts. Tin was fair, good aircleaner.  Crank doesn't look real scored, but bad rod looks like it heated up on that journal, might be turn able IF you can find new rods. Any interest, just pm me.  Huntington, IN 46750
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 23, 2014 - 08:23 AM
GL, is that a series 1 or 2 KT17. You can tell from the spec number. If it's higher than 24300 it's a series 2. You can also look for physical differences if the tag is missing, as outlined here. http://gardentractor...-and-2-engines/
#3 glgrumpy OFFLINE
  • 8,621 Thanks
  • 7,926 posts
Posted May 23, 2014 - 02:29 PM
Pretty sure Series 1, would have to check # to be sure, BUT, most series ll had big label and none on here anywhere. Didn't really make them much better. Not till they came out with 18hp twin did they have them right. Have starter and air cleaner, exhaust probly only fit a Wheelhorse C 175, but don't know. Couple shots of junk, but nothing real laid out to show.
Edited by glgrumpy, May 23, 2014 - 10:21 PM.
#4 OutBurst OFFLINE
OutBurst
  • 6 Thanks
  • 10 posts
Posted October 04, 2014 - 04:54 PM
Do you have the ignition coil off this?
#5 glgrumpy OFFLINE
  • 8,621 Thanks
  • 7,926 posts
Posted October 19, 2014 - 09:21 AM
Coil had one wire term broken, and a wire soldered to it, cobbled up. It sold at the swap meet this summer and rest of stuff pretty much thrown away now. Sorry!  not much interest in the parts like I figured. I did use the carb on my K single after changing the throttle and choke shafts, and it worked good!
