New Bucket For My Fel With Cutting Teeth
9 replies to this topic
#1 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 22, 2014 - 07:07 AM
Just built this FEL bucket with Cutting Teeth. Just need to prime, paint, and dig now!
  • Alc, hamman and boyscout862 have said thanks
#2 TomLGT195 OFFLINE
TomLGT195
  • 4,015 Thanks
  • 2,883 posts
Posted May 22, 2014 - 07:11 AM
nice job. glad to see its a little smaller so it doesn't overload the tractor, knowing it will be for dirt, gravel, etc    Tom
#3 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,539 Thanks
  • 2,561 posts
Posted May 22, 2014 - 07:47 AM
Looks good, what did you make the teeth out of?
I've been wanting teeth on my loader bucket for a long time, I always thought they would be handy!
#4 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 22, 2014 - 09:58 AM
It's made from 1/4" plate steel.
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 22, 2014 - 10:43 AM
Looks like it will bite in pretty good.  Typically you would use hardened steel for teeth on a bucket. You'll have to try it and see if it holds up.
#6 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,887 Thanks
  • 10,050 posts
Posted May 22, 2014 - 01:04 PM
I wish I had one of those for dandylions.
#7 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted May 22, 2014 - 02:29 PM
looks like sickle bar teeth
#8 olcowhand OFFLINE
  • 42,433 Thanks
  • 31,812 posts
Posted May 22, 2014 - 02:35 PM
I'm afraid you'll be bending these teeth very fast if digging anything but soft ground.  And once even one gets bent, your digging will get very difficult.  Not trying to be negative at all, but I've dealt with 1/4" plate a lot, and it's not that strong for this application.  Hope I end up wrong though.
  • superaben and FilledTires have said thanks
#9 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 22, 2014 - 03:51 PM
Hmmm. You are probably right. I may have to rethink that. I guess I should have made teeth from square tube with angles cut and welded into them.
#10 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 22, 2014 - 03:54 PM
Thank you all for your thoughts. I am going to take this back to the drawing board and show you all version 2.0 in a little while.
