Onan Fuel Lines
1 reply to this topic
  • 694 Thanks
  • 520 posts
Posted May 21, 2014 - 02:33 PM
Replacing the fuel lines on my JD 318.   , wondering why there are
two extra ports (in and out) on the pump?
Also, do I need to prime it somehow when I first start it, or will it pickup fuel on its own?
Heres a photo, didn't turn out as good as I wanted ,but I think you can see what I'm
asking about......
#2 olcowhand ONLINE
  • 41,827 Thanks
  • 31,619 posts
Posted May 21, 2014 - 06:57 PM
No idea why the extra ports.  They are blind anyway.  If the pump is good, it'll prime itself, but will take some cranking the engine over.  I always just take the breather top off & crank off spurts of carb cleaner till the gas gets to the carb.  Saves wear on the starter & from draining the battery.
  • WHdbJD said thank you
