My custom 10 has always started hard and worse after it sat all winter,it seemed like the starter was working hard to turn it over even with a starter change. I went to start it for the first time this year yesterday and it just cranked and I think I started to smell the ignition switch get hot,I checked it and no spark so I let it sit for a hour and then it fired right up. Today I picked up a Ford style solenoid and made new battery cables and the starter spins much faster then it ever had,I do have another custom 10 that is about the last year made that has a solenoid from the factory and the starter on it is a little slow so I think its going to get the solenoid and battery cables changed too.
71 Custom 10 Starts Easier With Solenoid
#1
OFFLINE
Posted May 20, 2014 - 09:53 PM
- Alc and jaysgt18 have said thanks
#2
OFFLINE
Posted May 20, 2014 - 09:57 PM
#3
OFFLINE
Posted May 20, 2014 - 10:16 PM
I am thinking it was the new battery cables that made the most difference and suprised a solenoid was not installed at the factory since a lot of power goes through the ignition switch and can get hot. My 71 originally had a switch on the clutch which made for a very long battery cable that was probably not a problem when new but 40 years later the cables go bad,a p/o took the switch off and bolted the cables togather so with the solenoid I was able to make a much shorter cables and made them from a thicker wire.
Edited by junkyardjeff, May 20, 2014 - 10:33 PM.
- MH81 said thank you
#4
OFFLINE
Posted May 21, 2014 - 05:14 AM
The resistance in the entire circuit needs to be as low as possible to get the speed up on the starter. Starting at the + battery post and ending back at the -post. Don't forget the common return from the engine to the battery - terminal. This connection is just as important as any other but often gets neglected. I often wonder what these older solenoids look like inside after 40 years of service.
#5
OFFLINE
Posted May 21, 2014 - 07:48 AM
I forgot about a chassis to motor ground and will make one tonight.
#6
OFFLINE
Posted June 22, 2014 - 08:36 AM
