318 Fuel Pickup Tube Removel
6 replies to this topic
#1 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted May 20, 2014 - 09:16 PM
What is the proper way to remove? Do you pull fitting out of grommet or pop hole thing out at one time?
  • A.C.T. said thank you
#2 Hammerdown OFFLINE
Hammerdown
  • 127 Thanks
  • 74 posts
Posted May 21, 2014 - 07:26 AM
Hello Gopher
The Onan Fuel pump's impulse line is located on the rear of the fuel pump and commonly held in place with a spring clamp. It can be removed with a set of Plier's as well as the Impulse tube clamp that is located on the engine block just above the oil filter adoptor. I hope this helps, Hammerdown
Edited by Hammerdown, May 21, 2014 - 07:26 AM.
#3 D318 OFFLINE
D318
  • 1 Thanks
  • 5 posts
Posted August 06, 2014 - 01:16 PM
I also need to check strainers on Fuel Pickup Lines in Gas Tank. Is there a procedure for removing Lines from Tank or is it just pull them out and hope they won't leak when you replace them?
#4 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted August 06, 2014 - 06:00 PM
You can pull out the one on the left if standing behind tank. The one on the right the reserve line has a rubber hose with clamps to extend it lower in tank if you pull that elbow out the hose will come off in tank. Then you have to drain tank to recover hose and strainer. I used my old bushing real pain getting back in likely swollen from gas if I do it again I'll buy all new tubes and bushings.
  • Alc and D318 have said thanks
#5 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 07, 2014 - 02:02 PM
I had this problem with mine.  The pickup tube with the strainer inside the tank completely rotted, both of them. The bushing I still haven't been able to get back in place and not sure how to resolve this issue.
Where do you get the pickup tubes that these have on them? And the bushing??
#6 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted August 07, 2014 - 05:38 PM
John Deere -parts catalog say they are still available so you should be able to get them at any John Deere dealer.
#7 Alc ONLINE
  • 7,131 Thanks
  • 7,533 posts
Posted August 08, 2014 - 05:39 AM
I bet my 318 has the same pick-up tube problem , one of the hoses must have rotted off , looks like that's going to be an end of season project
