Question On Mtd 995
10 replies to this topic
#1 catfisherokie OFFLINE
catfisherokie
  • 14 Thanks
  • 31 posts
Posted May 20, 2014 - 12:10 AM
Hi everyone. I'm curious to know if the grille, hood and other parts from other MTD models will interchange with the 995? The 990 sure looks close to the same as the 995.
Thanks for any info!
Bill
#2 glgrumpy ONLINE
  • 8,746 Thanks
  • 7,983 posts
Posted May 20, 2014 - 07:45 AM
Not sure on model by numbers, BUT, some had start gen and needed bulge on left side of hood to clear and others with standard starter had no bulge. SO, keep eye on that for your needs. Epay has parts most times for these, grills and hoods quite often. Prices vary all over tho, so shop some.
  • catfisherokie said thank you
#3 cityboy2977 OFFLINE
cityboy2977
    ordinary average guy
  • 117 Thanks
  • 179 posts
Posted May 20, 2014 - 02:28 PM
990 and 995 are two different animals. besides wheels, very few parts are the same.
990
995
#4 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted May 20, 2014 - 03:18 PM
Bill
I've owned versions of both machines. MTD make a bunch of tractors for private label, including Dayton, Farm King?, White, etc.  The 995 series has a Kohler M18 twin engine, while the 990 series has a 16hp B&S single. Both are great machines, but the 995s have a frail steering sector and pinion that tends to "skip" when too much load is applied when turning.
Regards,
Smitty
#5 catfisherokie OFFLINE
catfisherokie
  • 14 Thanks
  • 31 posts
Posted May 20, 2014 - 04:47 PM
990
995
I was afraid as much. I have not had much success finding parts so far. I'll keep on digging though.
#6 catfisherokie OFFLINE
catfisherokie
  • 14 Thanks
  • 31 posts
Posted May 20, 2014 - 04:51 PM
Regards,
Smitty
Mine is a 1981 with an 18 hp twin Briggs. The steering is one of the things that needs attention on mine as well.
#7 glgrumpy ONLINE
  • 8,746 Thanks
  • 7,983 posts
Posted May 20, 2014 - 08:48 PM
yeah, OK. That looks a lot like my late model White was and it had a Vanguard V-twin in it and diff modern metals then. quite diff than my 990's. Might find more as a White used.
#8 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted May 20, 2014 - 10:55 PM
I stand corrected... it IS a twin Briggs... I have a Dayton 3Z68B... great little machine other than the steering sector.  I plan on either putting in a Ross gear out of a JD or Cub Cadet, or power steering.  Then, I"ll convert the travel lever to foot pedal Ala Bolens and put front spindles with bearings in the wheel hubs and she'll be a screaming machine.
Some Parts are still available through MTD--I'm pretty sure I posted an owner's guide in the manuals section.  If not, I'll upload one right away.
I've posted some pics and a data sheet.  The 3Z678 was 16 hp, the 3Z678B was 18 hp.
Smitty
IMG_20130521_132251_428.jpg IMG_20130521_132308_071.jpg IMG_20130521_132339_130.jpg Attached File  Dayton 16hp Specsdayton 2-10 ocr.pdf   70.64KB   106 downloads
  • VTXrider said thank you
#9 catfisherokie OFFLINE
catfisherokie
  • 14 Thanks
  • 31 posts
Posted May 20, 2014 - 11:16 PM
Smitty
attachicon.gifIMG_20130521_132251_428.jpgattachicon.gifIMG_20130521_132308_071.jpgattachicon.gifIMG_20130521_132339_130.jpgattachicon.gifDayton 16hp Specsdayton 2-10 ocr.pdf
Man that is a fine looking tractor! Great ideas on the steering. You obviously know your way around different brands of tractors! I'm just getting my feet wet.
#10 glgrumpy ONLINE
  • 8,746 Thanks
  • 7,983 posts
Posted May 21, 2014 - 01:54 PM
Smitty, that IS a nice color on there. Might have to look into something like that for my 990. Is that a car paint or rattle cans or what color?  I like to paint mine diff than others just to be diff and more showy.
#11 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted May 21, 2014 - 05:13 PM
It was painted that way when I got it--the PO had repainted it, though the gold metal flake IS original Dayton Color. I think it was done with a spray gun as it's pretty consistent. I've seen the same body panels and hoods on other MTD-based machines as well... can't remember the brand names right off, though.
Smitty
