Kohler Carb Gasket
4 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted May 19, 2014 - 08:35 PM
I am in the need of a carburetor bowl gasket. Its on a 10 hp kohler. What part number would that be?
#2 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted May 19, 2014 - 08:41 PM
Have you looked in the manuals on the forum?
The info you are looking for should be available at your finger tips.
#3 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted May 19, 2014 - 09:15 PM
Carter N bowl gaskets are cheap as long as you want the O Ring only.  I sell them for $1.25 each.
Howeever, the best thing to do is to buy the rebuild kit.  Both gaskets, nut gasket, and the needle and seat.  Cheap enough at $12, and it will save you some leaks.
Ben W.
  • boyscout862 and zippy1 have said thanks
#4 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted May 19, 2014 - 10:54 PM
the old gaskets and needles were not made for today's unleaded gas
they will last if you use them and not let them sit for long periods of time
the newer gaskets and needles will last longer now with the unleaded gas
and the new  E85 ethanol some are having problem with it with they carbs
you might have to rebuild your carbs sooner than with unleaded gas
#5 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted May 19, 2014 - 11:34 PM
Ben W.
X-2 :thumbs:
