Working On The 990
31 replies to this topic
#16 Sawdust OFFLINE
Sawdust
  • 6,220 Thanks
  • 3,581 posts
Posted May 26, 2014 - 12:12 AM
Could the wrong filter cause this? It's got a stp oil filter on it now(recently changed by the po)?
Sent from my SAMSUNG-SGH-I437P using Tapatalk
Fram PH16 is recommended. 20W oil is recommended but hard to find. 30w or 10W-30W will work fine.
  • BairleaFarm said thank you
#17 olcowhand OFFLINE
  • 43,184 Thanks
  • 32,014 posts
Posted May 26, 2014 - 02:21 AM
I like to use 15w40 in worn hydro's myself.
  • BairleaFarm and Sawdust have said thanks
#18 Sawdust OFFLINE
Sawdust
  • 6,220 Thanks
  • 3,581 posts
Posted May 26, 2014 - 08:02 AM
Kind of like a stronger cup of coffee when we get older right :D
  • olcowhand and BairleaFarm have said thanks
#19 olcowhand OFFLINE
  • 43,184 Thanks
  • 32,014 posts
Posted May 27, 2014 - 07:46 AM
Right!  :thumbs:
#20 HALFSCALE ONLINE
HALFSCALE
  • 520 Thanks
  • 544 posts
Posted May 27, 2014 - 09:26 AM
"W" stands for winter , not weight. 15w40 means it will not get any thicker than 40 in the cold and no thinner than 15 in the heat. Most hydraulic oil is straight 30, including ATF. If you use a thicker oil , it will push and not get between were it has to go , it will run hotter and cause metal damage.
#21 TAHOE OFFLINE
TAHOE
  • 8,340 Thanks
  • 5,820 posts
Posted May 27, 2014 - 09:48 AM
Could be. STP filters are made by Champion labs who makes Fram and those are junk too.
#22 olcowhand OFFLINE
  • 43,184 Thanks
  • 32,014 posts
Posted May 27, 2014 - 10:33 AM
I'm pretty sure most ATF is 10W.
#23 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted May 27, 2014 - 11:03 AM
most all Hydraulic fluids are either 10 or 15 wt.
  • TheFarm2004 said thank you
#24 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted June 02, 2014 - 09:55 AM
Ive also noticed she rolls down hill when the engine is off.  Ive always had a hydro sit where I park it.  Is it hard parts that are worn or things like orings?
#25 olcowhand OFFLINE
  • 43,184 Thanks
  • 32,014 posts
Posted June 02, 2014 - 10:11 AM
Most likely hard parts.
#26 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted June 02, 2014 - 10:26 AM
SUPER
#27 olcowhand OFFLINE
  • 43,184 Thanks
  • 32,014 posts
Posted June 02, 2014 - 11:57 AM
When they go faster downhill, that's more or less the speed it should go at that setting on level ground.  On uphills with a worn hydro, the pressure rises, so with a worn hydro, oil is bypass in the worn areas.  Uphill slows down due to bypassing, then when you top the hill, the load falls off, allowing it to speed up to full capacity...or a tad faster even.
#28 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted June 04, 2014 - 07:02 PM
I know nothing about hydros but do they have a spring loaded bypass?
#29 olcowhand OFFLINE
  • 43,184 Thanks
  • 32,014 posts
Posted June 04, 2014 - 08:56 PM
They do have pressure reliefs, but the bypassing I'm speaking of is at the piston spool face where it mates to the housing.  I'm not familiar at all with the Eaton units though, having never been inside one to know.
#30 twostep ONLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted July 11, 2014 - 09:47 AM
Selling this already?
