Working On The 990
31 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 19, 2014 - 12:59 PM
http://gardentractor...uestions/page-1
Ive decided to start a new thread since the questions I initially had were answered in the previous thread.
The little ive mowed with this makes me want my parts to get here now.  Im ready to see how it does with the whole yard.  I initially planed on putting the 3ph on a separate valve but as easy as the deck came off I may not do that now.  Ill have to see how easy it is to reinstall it.
  • Sawdust said thank you
#2 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 19, 2014 - 02:06 PM
Petes small engine seemed to have the best prices when you included shipping.  I didn't want to order from several places.  His prices...
65-220-MT 388 Blade Adapter   $7.85
3356-MT 032-50 Blade Replaces 742-0171  $12.60
75-079-MT Belt Replaces MTD 754-0197   $32.95
I placed the order last night and just got notification of it shipping.
  • Sawdust and Bunker Buster have said thanks
#3 VTXrider OFFLINE
VTXrider
  • 517 Thanks
  • 376 posts
Posted May 19, 2014 - 02:32 PM
I have bought many items from Pete's Small Engine. No problems, ever.
Just in case you did not notice, There are two carriage lift holding brackets, one on each side to hold the it up when using other implements. I made mine for the tractors that did not have them.
  • BairleaFarm and Sawdust have said thanks
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 19, 2014 - 03:09 PM
I haven't noticed.  I wonder if mine has them?  I for sure wont be messing with the hydraulics now.   Thanks for the info.
#5 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 20, 2014 - 04:42 PM
Sanded and second to last coat applied. I'm a great Dane dealer. Our paint is good but the nozzle sucks. I dint think I'll use it for the last coat.
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 22, 2014 - 05:25 PM
It's amazing how worn a set of blades can get. Years of sharpening. The New adapters are aluminum and thicker.
I should get the deck on, hydro friction thingy adjusted tomorrow. Hopefully ill be able to mow a little.
  • twostep and Sawdust have said thanks
#7 Sawdust ONLINE
Sawdust
  • 5,656 Thanks
  • 3,370 posts
Posted May 22, 2014 - 05:34 PM
Looking real good. I'm hoping to do some sand blasting on mine this weekend. Have you painted any of the frame or tunnel yet....will this be black.
#8 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 22, 2014 - 06:37 PM
I'm not painting anything else right now. I just did the fenders due to the rough condition.
Sent from my SAMSUNG-SGH-I437P using Tapatalk
#9 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 24, 2014 - 04:43 PM
Tap time lol
I added a grease fitting to the gear box. It was empty when I took the cover off.
Someone has messed with the idlers but I halfway figured it out. Someone has added stuff to.
I also adjusted the friction on the hydro so it more stays where I put it.
#10 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 24, 2014 - 07:47 PM
Finally got to mow with her tonight. It mows great but there are a few issues I don't like. there is a vibration. I feel it bad in my feet. This could be because I have the fenders off. It speeds up bad when going down hill. The seat seems really high. Maybe I have short legs but I've never noticed it.
#11 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 25, 2014 - 10:13 AM
More mowing today. I hate the fact this thing speeds up and slows down depending on the terrain.
#12 Sawdust ONLINE
Sawdust
  • 5,656 Thanks
  • 3,370 posts
Posted May 25, 2014 - 06:00 PM
Have you done any adjusting on your govenor, sometimes they want to rev up too high under load.
#13 olcowhand ONLINE
  • 41,134 Thanks
  • 31,413 posts
Posted May 25, 2014 - 06:40 PM
David, sounds like wear in the hydro causing the speed changes with terrain.  Changing oil to a thicker viscosity usually helps with that.
#14 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 25, 2014 - 07:24 PM
It's not the engine it's the hydro. It's running atf. What oil would you suggest?
#15 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 25, 2014 - 10:36 PM
Could the wrong filter cause this? It's got a stp oil filter on it now(recently changed by the po)?
