Splined Shaft Coupler
18 replies to this topic
#16 coldone ONLINE
  • 1,661 Thanks
  • 1,682 posts
Posted June 04, 2014 - 04:47 PM
Acetone and dry ice will get it down to -70C
  • Gav694 said thank you
#17 olcowhand ONLINE
  • 41,821 Thanks
  • 31,616 posts
Posted June 04, 2014 - 04:52 PM
Will a household freezer be enough or are we speaking liquid Nitrogen
Brett's method would do fine.  But don't drop it at that cold a temp...it could break!  And have some very good insulated gloves on!!!!
#18 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted June 05, 2014 - 03:04 AM
I have left it with the welders at work to see what taccurate do to repair the crack.
For the sealing surface I plan to have a sleeve turned and press it on. the original seal was 30mm ID but I can get one that is 31mm ID and it will still fit into the housing.
the bigger seal combined with turning a bit of the OD of the coupler should allow a sleeve with a thick enough wall to prevent it splitting when pressed on. I Hope :D
Keith if you do internal splines in carbide do you spark them out?
Wire edm. And it does it with ease and can give you a √32 finish and it can do it with a .002 inch wire. Very acurate too.
  • limebuzz, Bruce Dorsi and Gav694 have said thanks
#19 Gav694 OFFLINE
  • 267 Thanks
  • 184 posts
Posted June 05, 2014 - 03:55 PM
OK so I now have it welded, excuse the poor photo
And I found these repair sleeves on the internet
So A pal of mine is going to turn the OD to 29.41mm from 30mm and I will install the sleeve with Loctite and see how it looks
  • olcowhand, MH81 and coldone have said thanks
Also tagged with one or more of these keywords: gutbrod
