Another 990 Wir Question
5 replies to this topic
#1 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted May 18, 2014 - 06:57 PM
just finished all my wireing so i decided to see if it would at least turn over, i decided to check out the lights and they work as they should. and the selenoid just cliked would that be a bad one. also i usd my test light checked A side on the starter , gen and the light is one does the A side always hot. i rewired the same as on the schematic.  before i get a new solenoid  is there any thing i could  or i could check, i thought it was ok before i started the tear down.  as a rule of thumb it works or it doesnt. would anybody agree.
#2 KennyP ONLINE
  • 41,451 Thanks
  • 47,382 posts
Posted May 18, 2014 - 06:59 PM
Might check for a good ground!
#3 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted May 18, 2014 - 07:03 PM
does the solenoid have to be grounded to the tractor as well.
#4 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted May 18, 2014 - 07:12 PM
Most solenoids use the metal mounting bracket as the - connection back to the battery, through the engine block.  If it only has 3 terminals, one to energize the solenoid and 2 big ones to carry the current to the starter, then it needs to be grounded back to the battery - through the chassis or a separate wire.
#5 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted May 18, 2014 - 07:19 PM
ok ill check that out, come to think of it i did paint the solenoid all except the 3 terminals maybe should not have done that.
#6 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted May 19, 2014 - 03:05 PM
well i took the solenoid off and cleaned the paint off the brkt. and ran a ground wire hooked up and still just click,click,clicked. so i pulled the one off the other 990 and i get the same thing, at this point iam a little confused, so i took off the other gen/starter then she turned over. i was a happy man. and i thank all of you that helped me . also pulled the other gen apart it had a broken wire at the A pole. thanks gary.
  • Sawdust said thank you
