Mf 10
serial no.
28 replies to this topic
#16 MH81 OFFLINE
  • 29,979 Thanks
Posted May 20, 2014 - 06:39 AM
So where is the best place to get parts for this tractor, so far I believe I will need breaker points and condensor and a head gasket and a carb kit, just got the thing turning over on the starter yesterday.
Thanking everyone for there fast curtious replys!!attachicon.gifIMAG1364.jpg
That unit does not have breaker points. It is electronic.
You will want to be very careful working on it to not apply power to the wire that goes to the spark module, that will cause an expensive repair.
The Spark on this is what is know as CDI (Capacitive Discharge Ignition) and they are no longer made by the original manufacturer... The used ones command a premium price and the available repair/replace systems are not cheap either, but far better than disposing of the unit.
First thing is to make sure it's the OEM switch, if not, we will have lots of questions.
Assuming the switch is OEM, Remove the spark plug and ground it, then turn it over, watching for spark. If you have spark it's a very good thing, if not, we have a few tests to run.
  • 1ijack60 said thank you
#17 propane1 ONLINE
propane1
  • 9,744 Thanks
  • 4,517 posts
Posted May 20, 2014 - 03:16 PM
I am in Charlottetown PEI .  Noel   And where are you located ?
#18 1ijack60 OFFLINE
1ijack60
  • 10 Thanks
  • 11 posts
Posted May 22, 2014 - 06:21 AM
I am in Hantsport N.S. I have a MF10 and a JD 110.
  • propane1 said thank you
#19 1ijack60 OFFLINE
1ijack60
  • 10 Thanks
  • 11 posts
Posted May 22, 2014 - 06:24 AM
Motor turns over but slowy with battery fully charged, might the starter be draging and is there a kit you can get for that? Tried the spark but there dosen't appear to be any.
#20 MH81 OFFLINE
  • 29,979 Thanks
Posted May 22, 2014 - 06:36 AM
I don't know if you have a starter repair place nearby.
Probably bushings and brushes, if you're comfy taking it apart, they aren't complicated in there and a good cleaning and lube will sometimes do a lot.
As for the spark, we have a couple of tests for you, but we do need the tractor rolling over.
#21 HowardsMF155 ONLINE
  • 2,985 Thanks
  • 3,026 posts
Posted May 22, 2014 - 08:33 AM
I'll chime in and suggest that you might want to remove the belts from the motor as you try to diagnose slow starter issues.  If something is binding on the belts, the engine will not turn as fast as it should.
  • MH81, IamSherwood and 1ijack60 have said thanks
#22 1ijack60 OFFLINE
1ijack60
  • 10 Thanks
  • 11 posts
Posted May 22, 2014 - 04:27 PM
Yeah I am comfortable taking it apart but where can I get brushes and bushing for this tractor?
#23 1ijack60 OFFLINE
1ijack60
  • 10 Thanks
  • 11 posts
Posted May 22, 2014 - 07:46 PM
Where can I get a starter kit for this tractor,bushings, brushes?
#24 MH81 OFFLINE
  • 29,979 Thanks
Posted May 22, 2014 - 09:04 PM
You may have to take it apart and get sizes, but There are several Site Sponsors who should be able to get them for you.
I will let them chime in as needed.
#25 propane1 ONLINE
propane1
  • 9,744 Thanks
  • 4,517 posts
Posted May 23, 2014 - 03:56 PM
I have some relatives in Kentville, Kingsport and areas.  On my wifes side.  Noel
#26 propane1 ONLINE
propane1
  • 9,744 Thanks
  • 4,517 posts
Posted May 24, 2014 - 05:41 AM
Have you got it turning over and running yet. Noel
#27 MH81 OFFLINE
  • 29,979 Thanks
Posted May 24, 2014 - 05:44 AM
I was just thinking, it might get more exposure as an actual wanted ad.
I would suggest making a separate wanted ad in the parts area.
#28 1ijack60 OFFLINE
1ijack60
  • 10 Thanks
  • 11 posts
Posted May 30, 2014 - 06:17 AM
Got the starter rebuilt on the old MF10, turns over alot better and has god fire to the spark plug!
  • MH81, IamSherwood, HowardsMF155 and 1 other said thanks
#29 MH81 OFFLINE
  • 29,979 Thanks
Posted May 30, 2014 - 06:26 AM
Whew, that's all great news.
:dancingbanana:
