Ford Lgt 165 With Tranny Issues
17 replies to this topic
#1 rickbrown OFFLINE
rickbrown
  • 2 Thanks
  • 9 posts
Posted May 15, 2014 - 06:35 PM
My ford lgt 165 started losing speed last year, I changed fluid and filter but it didn't seem to help. Also when I checked to fluid level it was very frothy and flowing out the inspection hole, it was only filled just until it started to run out inspection hole. Now the mowing deck is difficult to raise and lower as if there isnt enough power to move it. Does anyone have any ideas?
#2 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted May 15, 2014 - 06:56 PM
:wave: Welcome to the forum! I'm sure someone can get you an answer. I haven't had that happen as yet.
  • Chopperhed said thank you
#3 TomLGT195 OFFLINE
TomLGT195
  • 3,833 Thanks
  • 2,816 posts
Posted May 15, 2014 - 07:30 PM
Welcome to GT Talk ! No answer here ,but be patient someone will be along soon. Tom
p.s. As always pics are a great bonus
Edited by TomLGT195, May 15, 2014 - 07:30 PM.
#4 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted May 15, 2014 - 08:22 PM
No answer here either. I have two of them and they work good. But I would change fluid and filter again. Sounds like water in the fluid. Noel
#5 rickbrown OFFLINE
rickbrown
  • 2 Thanks
  • 9 posts
Posted May 16, 2014 - 04:45 PM
Thanks for the suggestion, I can't see how water could get in but could it be pulling in air somewhere.
#6 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 16, 2014 - 08:40 PM
Actually, that was my thought as well another thought is that the charge pump might be cavitating. water could possibly get in through the vent, or from condensation. Cavitiation would be caused by a plugged inlet forcing the pump to starve.
#7 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted May 18, 2014 - 10:21 AM
Would air cause the oil to froth? I think water would but not air. What kind of oil do you have in it?
#8 rickbrown OFFLINE
rickbrown
  • 2 Thanks
  • 9 posts
Posted May 18, 2014 - 05:52 PM
Its got HY-TRAN ultra hydraulic transmission oil, whatever is going on the volume of fluid seems to increase. I drained the fluid today and then refilled, there is what appears to be a fitting on the hydraulics to raise and lower the deck to bleed air as you would a brake line. This appears to have helped a little. I haven't seen a service manual, if one exists I'd like to see it. Anyways thanks for the help.
#9 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted May 18, 2014 - 05:57 PM
Here's a repair manual!
#10 rickbrown OFFLINE
rickbrown
  • 2 Thanks
  • 9 posts
Posted May 18, 2014 - 06:03 PM
Thanks a lot Kenny , hopefully I can figure this out.
#11 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted May 18, 2014 - 06:13 PM
That is not an issue I have come across, so I can't offer any help at this point. But it does sound like you have a way that air is being sucked into the pump somehow!
#12 rickbrown OFFLINE
rickbrown
  • 2 Thanks
  • 9 posts
Posted May 18, 2014 - 06:18 PM
hey I'm trying to download manual but I'm not being allowed to any ideas why?
#13 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted May 18, 2014 - 06:23 PM
You may need to wait until tomorrow! We limit new members so folks don't raid the manuals!
#14 rickbrown OFFLINE
rickbrown
  • 2 Thanks
  • 9 posts
Posted May 18, 2014 - 06:27 PM
Ok thanks I'll try  tomorrow
#15 Cvans ONLINE
  • 6,649 Thanks
  • 6,130 posts
Posted May 18, 2014 - 10:50 PM
Wish we lived closer as I have one of those hydros setting out here that is going to be taken in for scrap. For that price you could have had it. Worked fine when I took it out.
As I recall there is a tube or thin return line at the bottom of the hydro unit on the outside. Maybe 5/8" OD. Make sure this hasn't been damaged or flattened so the flow is restricted.
Hope you get it figured out.
