A Tic In My Bolens Gardener Motor
8 replies to this topic
#1 boli51 OFFLINE
boli51
  • 37 Thanks
  • 38 posts
Posted May 15, 2014 - 04:13 PM
hey bolens and Wisconsin engine guys. looking for some help with the cause of  a fairly loud ticking coming from my Wisconsin AB engine on my gardener. I'm more familiar with briggs and since this noise is new to me I would like to find out what it is before I damage the engine. I was told that its was coming from the wico magneto that this engine uses but I'm not confident with that answer. Any ideas???
#2 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,102 Thanks
  • 10,172 posts
Posted May 15, 2014 - 04:49 PM
I hate ticks, too. As for your engine unless you get enough of them to plug up the aircleaner, they probably won't hurt anything. If your really bothered, Frontline works pretty good on a Wisconsin. Less so on a Chinese knock off.
  • TomLGT195 and boli51 have said thanks
#3 pharmer ONLINE
pharmer
  • 894 Thanks
  • 786 posts
Posted May 15, 2014 - 05:10 PM
And watch for Lyme Disease
  • boli51 said thank you
#4 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,789 Thanks
  • 5,092 posts
Posted May 15, 2014 - 05:43 PM
If its just ticking while you are slowly turning the engine such as to start it that would be the impulse in the mag.  Totally normal.
If you haven't started the engine yet you will notice the clicking stops once the engine is running.   GOOD LUCK!!!
#5 boli51 OFFLINE
boli51
  • 37 Thanks
  • 38 posts
Posted May 15, 2014 - 06:36 PM
O.K. I know about the click/tic as I pull on the starter rope when I get to the barn in the morning I'll start it and see if it goes away. So if it doesn't????
#6 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted May 15, 2014 - 07:34 PM
Can you post a video walk around so we can hear the tic from various angles?  That might help us figure out what it is & where it is coming from.
#7 boli51 OFFLINE
boli51
  • 37 Thanks
  • 38 posts
Posted May 16, 2014 - 06:40 PM
The video is something I'll have to practice with, haven't done one before but will try. I started it this morning and the clicking goes on even after it starts but it does start easily. I took the lifter cover off in the front of the engine, pulled the spark plug and turned the motor over by hand and it seemed to coincide with the valves opening and closing. The gap doesn't look to wide but I'll put a gage on them in the morning. It sounds like a spring returning something with a snap, metal against metal. I did notice one thing that seemed odd, that if turned slow the click was very clear however if I put the starter rope on and pulled fast there was no click.
Much thanks for any advice.
#8 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,102 Thanks
  • 10,172 posts
Posted May 16, 2014 - 08:02 PM
Sticking valve?
#9 rust addict OFFLINE
rust addict
  • 243 Thanks
  • 174 posts
Posted May 20, 2014 - 12:38 PM
Spotted Beaver too. :thumbs:
  • pharmer said thank you
