Hydrostatic Pump Psi And Alternators
3 replies to this topic
#1 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted May 15, 2014 - 08:03 AM
I have a Steiner 220 putting out 1200 psi on an output port on the hydraulic control valve bank.What should the pump psi be and is it likely that the valve bank has a lower pressure relief valve and can I raise the pressure if so?
Is a permanent magnet alternator directional?
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 15, 2014 - 08:08 AM
Alternator doesn't care which way it spins.
  • Username said thank you
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 15, 2014 - 11:14 AM
Hard to say on the Steiner. 1200lbs would be low for a compact tractor which are typically in the 2000-2500 range, but a bit higher than most GT's which are usually in the 600 to 1k psi range. A brushless PM alternator won't care what way it's turned but a brushed alternator that has been used in one direction will be noisy and hard on the brushes if turned the other way.
#4 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted May 15, 2014 - 02:08 PM
Well I have a forklift attached to it and I am only getting less than 500 lbs of lift instead of the 1300 that it is rated at.It was run with and electric over hydraulic pump with obviously a lot more pressure.I would have like to run it with on board hydraulics but I don't think that is going to happen.
