Maintenance On X738 (4Wd)
5 replies to this topic
#1 dld542004 OFFLINE
dld542004
  • 2 Thanks
  • 5 posts
Posted May 15, 2014 - 07:54 AM
What is the CORRECT way to remove the vent plugs on the front axle of the John Deere X738 when changing the fluid?
#2 boyscout862 OFFLINE
  • 13,545 Thanks
  • 9,425 posts
Posted May 15, 2014 - 09:27 AM
Welcome to GTT. I do not have your answer but, someone will be along that can help you. Relax and enjoy the site. Good Luck, Rick
  • dld542004 said thank you
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 15, 2014 - 11:17 AM
Not sure what you mean by vent plugs. Is a 738 a hydraulic front wheel drive or the mechanical type like used on the older x585? That type of info. is generally in the Owners manual. A quick call to your local JD dealer service dept. should get you the info. you need.
#4 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,138 posts
Posted May 15, 2014 - 07:32 PM
Do not remove the plugs until you have drained everything and ready to refill the system. Remove the fill plug on the axle, and the vent plugs on both drive motors. Fill until you have fluid at both vents, then close everything up.
Are you doing a 50 hour service or are you at 100 hours already?
#5 dld542004 OFFLINE
dld542004
  • 2 Thanks
  • 5 posts
Posted May 16, 2014 - 04:45 AM
Planning ahead !  Making sure I have everything I need on hand. The vent caps take a BIG allen (Hex ) wrench.  Thanks
Edited by dld542004, May 16, 2014 - 05:06 AM.
#6 dld542004 OFFLINE
dld542004
  • 2 Thanks
  • 5 posts
Posted May 17, 2014 - 01:51 PM
While on the subject of maintenance,  I just changed the oil for the first time.  I traded my Z445 zero turn mower and got the X738.  Oil changes on Z445 E A S Y !!!  On X738 ...ARGGGH !!! Does anybody have recommendation on a tool to access the EXTREMELY hard to get at drain plug.  There's got to be an easier way.
