Help me choose an air compressor for sandblasting and shop.
#211
OFFLINE
Posted March 01, 2011 - 08:49 AM
#212
OFFLINE
Posted March 01, 2011 - 01:05 PM
#213
OFFLINE
Posted March 01, 2011 - 01:09 PM
your over thinking the pressure switch if you want I will take better pics for you and email them -we basically have the same thing
I know after it is finished I am going to be smacking my forehead saying duh. I have an idea of how the pressure switch and low oil level switch will go, the biggest part I don't know about is how it all comes together with the switches on the motor starter and which terminals they would go to at the bottom of the relay.
#214
OFFLINE
Posted March 01, 2011 - 01:22 PM
all I can say is its magic LOL wire it up like in my picture if you need better photos just say the word -I know a pic is worth a 1000 words
edit --I will get you the pics around dinner time
edited again
Edited by thecoater, March 01, 2011 - 01:56 PM.
#215
OFFLINE
Posted March 01, 2011 - 01:53 PM
If you have your starts switch circut figured out then its just a matter of putting the safty switches in series.
Hope that helps.
#216
OFFLINE
Posted March 01, 2011 - 04:01 PM
#217
OFFLINE
Posted March 01, 2011 - 04:04 PM
#218
OFFLINE
Posted March 01, 2011 - 04:14 PM
Should I add a distribution block to the motor starter box for the ground and common or will I be alright just running the ground to the motor and pressure switch and not ground the cabinet of the motor starter?
As far as Grounds go, you can just run the ground through the box and twist a pig tale with a wire nut off the ground and put it to a ground lug or to a mounting bolt. Earth grounds are usually uninsulated and basically they keep you from being shocked if a problem occurs.
I hope this makes sense.
#219
OFFLINE
Posted March 01, 2011 - 04:19 PM
#220
OFFLINE
Posted March 01, 2011 - 04:22 PM
I am also assuming I would have been fine using the 6-2(red/black/ground) wire I originally had but returned for 6-3(red/black/common/ground) because I thought I needed the common/neutral for the 110v relay circuit but as far as I can tell it isn't needed.
After I posted that I guess it would still be better to use the 6ga common and ground together for the grounding of everything since the 6ga may help carry the load better if needed?
#221
OFFLINE
Posted March 01, 2011 - 04:24 PM
You could have pulled a smaller seperate wire for ground leg with the other 6-2 you ran.
#222
OFFLINE
Posted March 01, 2011 - 04:30 PM
#223
OFFLINE
Posted March 01, 2011 - 04:32 PM
#224
OFFLINE
#225
OFFLINE
Posted March 02, 2011 - 06:03 PM
