Who Else Hates Ethanol!? Yuck!
gas fuel ethanol
25 replies to this topic
#1 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted May 14, 2014 - 06:22 PM
Take a look at my carb bowl.
I want to conduct a fuel breakdown test.  I am going to buy fuel from different gas stations, and set up samples in jars.  I will have a control jar for each.  Some jars will be open to air/atmosphere, others will be sealed.  I would like to add staaabil and other additives to them and see what happens.
Who else has nasty gas pics!?
Any other suggestions for my gas deterioration test?
  • hamman, tinbender7 and MFDAC have said thanks
#2 olcowhand OFFLINE
  • 39,715 Thanks
  • 30,983 posts
Posted May 14, 2014 - 06:24 PM
Oh don't get me started on this new blended fuel!  It's the scourge of the earth to me.  I'm a farmer, but not a grain farmer, so all the blended fuel does for me is drive up my feed prices I pay, and ruin carbs!
  I am much looking forward to your tests.
  • hamman, tinbender7 and superaben have said thanks
#3 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted May 14, 2014 - 06:42 PM
Up here one of the three in town gas stations sells "recreational gas" which is supposed to be alcohol free and 90 octane.  I have been using it in everything,, including for customers, except my truck and diesel engines for about four years now and it has made a big difference in the number of carb kits I have installed.  It does cost about the same as premium gasoline though.
  • Alc, hamman and tinbender7 have said thanks
#4 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted May 14, 2014 - 06:46 PM
Well, I would most def pay a little extra to get non ethanol gas.  I need to buy a drum of VP110 race fuel for my truck eventually.. My plan is to add a little to my small engine gas cans in hopes that the additives will make it keep longer.
  • hamman and tinbender7 have said thanks
#5 Bolens 1000 OFFLINE
  • 14,809 Thanks
  • 18,054 posts
Posted May 14, 2014 - 06:49 PM
Its a problem everywhere. Every Lawn and garden dealer I have spoke with have said the new fuel is just killing the carbs , eating the gaskets and bronze parts ect.  80% of mowers that are coming into shops are with fuel related ethanol problems.
With a shelf life of 30 days I guess that's to be expected :wallbanging:
WE WANT OUR OLD FUEL BACK!
#6 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,283 Thanks
  • 2,812 posts
Posted May 14, 2014 - 06:53 PM
I use what they call " Recreational Fuel" here locally. It's .40cents more a gallon but it has no ethonal in it.    Good luck with the test. Will be interested in the results.                                   Roger.
  • tinbender7 said thank you
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,530 Thanks
  • 9,826 posts
Posted May 14, 2014 - 07:02 PM
puregas.org is the site to visit, to find the station nearest you that carries non-ethanol fuel. You can edit existing info or add a station if one you know about isn't listed.
  • Alc, tinbender7 and TomLGT195 have said thanks
#8 KC9KAS OFFLINE
KC9KAS
  • 5,268 Thanks
  • 4,644 posts
Posted May 14, 2014 - 07:07 PM
It is my understanding that our county Co-op station has a pump with "non-ethanol", and is more expensive.
Ethanol fuel only has about a 30 day shelf life.
I hate the stuff! I add a can of Sea-Foam to every 5 gallon can of fuel I buy for the small internal combustion engines I have. I even put Sea Foam in the motorcycles. I don't add any conditioner to the truck, as gasoline doesn't stay in the truck very long!
#9 petrj6 OFFLINE
petrj6
  • 4,081 Thanks
  • 2,369 posts
Posted May 14, 2014 - 07:10 PM
   I don't know????  I have heard lots of complaints about ethanol but I myself have not had any issues.  I use all my stuff regularly or at least run it monthly, I did once put stabil in my Cadillac before I put it up for the winter but in the spring it ran like crap for the first two tanks of fuel till I got the stabil out.
#10 JDBrian OFFLINE
  • 9,599 Thanks
Posted May 14, 2014 - 07:11 PM
Here the high test does not have ethanol. I always use that in all my small engine equipment now.
#11 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted May 14, 2014 - 07:20 PM
Blended fuel may suck but I don't have a choice.
Because of that, I "try" only keep fresh fuel in stock. I drain anything that sits and only buy gas as needed.
Yes blended fuel sucks...
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 14, 2014 - 07:25 PM
been using it since the gas shortage in the 70s. maybe i don't know better but have no problems.
  • Lauber1 and tinbender7 have said thanks
#13 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted May 14, 2014 - 08:29 PM
Anyone else remember when you could actually light gas  with a match nowdays you cant even get it lit
  • MFDAC and Bill 76 have said thanks
#14 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted May 14, 2014 - 08:40 PM
That when we got it, back in 1978, been running it ever since and have never had a bit of trouble with it. I've seen several problems in other peoples stuff, like foam floats get eaten, and stuff that looked like rock candy in fuel bowls, so I suppose there is some problem with it. I believe some of it is the way you use and store your equipment.
#15 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted May 14, 2014 - 09:03 PM
I'll admit. I have not experienced any major issues with blended fuels. I do believe it raises the cost of fuel though.
Also tagged with one or more of these keywords: gas, fuel, ethanol
