Filters For Hydros ?
7 replies to this topic
#1 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted May 14, 2014 - 08:32 AM
I found a cross reference for the FF20 hydro filter. It is a Fram PH2844. This crosses to a NAPA 1410. This is a 21 micron filter. Is this small enough, or should I try to cross to a 10 micron. Napa also lists this for the Toro GroundsMaster 322D which I have.
  • boyscout862 and New.Canadian.DB.Owner have said thanks
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 14, 2014 - 10:35 AM
Kenny, if that FF20 has a standard Eaton or Sundstrand hydro couldn't you just use the OEM filter for another tractor that uses the same hydro. Or use that model to get a cross reference and verify what you've already found. It could be that a 10micron filter may have too much back pressure for your application.
  • jpackard56 said thank you
#3 skyrydr2 OFFLINE
  • 3,894 Thanks
  • 3,411 posts
Posted May 14, 2014 - 11:09 AM
Eaton I think recomends 13-18 micron filtration for these units but im not positive as my pdf reader is not behaving...
#4 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted May 14, 2014 - 12:25 PM
Kenny,,, I recently went on the Eaton web site..  ( If that is what you have )   And it says alot about the micron count and fluids..
I   personaly don't care for Fram.. They are cheaply made..  I use Wix,, which is Napa branded.. So that is good..
Back to microns,,,  In the eaton  web site,,   I'm not that smart to follow the teck lingo....
          Cleanliness  code   18 / 13  per sae j1165         That says,,,,2500 particles per milliliter greater than  5 UM...??????????
  I went and got the Napa  1307 and I'm useing  dex. 3   in my eaton 10
   In my eaton 12  ,, I use Wix 51410.     with type  F  trans fluid
  NOW if you don't have an Eaton,,,,,,,,,,    NEVER   MIND...... :smilewink:
  • MH81, GTTinkerer and jpackard56 have said thanks
#5 AlleyKatz51 OFFLINE
AlleyKatz51
  • 41 Thanks
  • 35 posts
Posted May 14, 2014 - 01:04 PM
Ditto the Fram, they are cheap made. Ditto the Wix :thumbs:, Wix are well made. Been using the NAPA 1307 for many years without any break downs at all.
Chuck
  • MH81, GTTinkerer and sodisr have said thanks
#6 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted May 14, 2014 - 06:07 PM
I don't want the Fram. Plan to go with NAPA. Just trying to find what filter to use as NAPA doesn't have a cross for the Sears filter #. The FF's are Eaton 11's with Hydraulic/Transmisson fluid.  The Toro is a Sundstrand 15.
#7 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted June 08, 2014 - 06:30 AM
I finally got around to changing filters on the FF and found out what I posted originally was not  totally correct. The Fram PH2844, NAPA 1410, and Wix 51410 are for screw-on filter adapters with 3/4"-16 threads. The Toro and both my FF's have a 1"-12 thread, so they take a NAPA Gold 1259 filter. Just wanted to clear things up. If you are going to change filters, take the old one off first to see what threads your machine has.
Edited by KennyP, June 08, 2014 - 06:52 AM.
Thread size
  • olcowhand, GTTinkerer and sodisr have said thanks
#8 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted June 08, 2014 - 12:32 PM
Not sure about today but a couple of years ago WIX made the good NAPA and Carquest filters along with the majority of the filters sold by Toro.
