Kroil?
23 replies to this topic
#16 KennyP OFFLINE
  • 41,529 Thanks
  • 47,427 posts
Posted June 23, 2014 - 06:40 AM
I think 50/50 acetone and auto trans fluid is just as good as anything.
I use that and PB Blaster for most things. Haven't noticed Kroil around here very much.
#17 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 23, 2014 - 10:41 AM
The absolute best penetrating oil I have EVER used is GM Heat valve lube !!! It is smelly stiff but it works !!! Kroil is my second go too. And if that doesn't work my torch does!! PB blaster was good when it was a catalyst now its just smelly and does not work... I won't even let it in my shop....
  • Bill 76 said thank you
#18 Sammy OFFLINE
Sammy
  • 8 Thanks
  • 16 posts
Posted August 19, 2014 - 10:11 PM
I too have had great success using Kano Lab's KROIL. Purchased a gallon a few years back,and still have some . Very distinctive smell and color.
#19 TheJunkKing OFFLINE
TheJunkKing
  • 32 Thanks
  • 18 posts
Posted September 14, 2014 - 06:47 PM
Kroil is the best!
You have to order it from www.kanolabs.com - I've never seen it anywhere in any store.
Back in 2007, Machinist's Workshop magazine ran a comparison of the most popular penetrating oils on the market and found that Kroil outperformed all the others, including PB Blaster and Liquid Wrench. See the attached PDF.
As someone mentioned above, the only thing they found that worked even better than Kroil is a 50/50 mix of acetone and ATF.
I just bought a case of AeroKroil. The stuff is absolutely great.
#20 KennyP OFFLINE
  • 41,529 Thanks
  • 47,427 posts
Posted September 15, 2014 - 06:22 AM
I keep a bottle of the ATF/acetone on hand all the time. I'm really happy with it. It has loosened bolts that have had many years rust on them!
  • Cvans said thank you
#21 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted September 15, 2014 - 03:00 PM
"Mouse Milk" What a HOOT!
#22 560Dennis OFFLINE
560Dennis
  • 11 Thanks
  • 20 posts
Posted May 21, 2015 - 08:17 PM
Works real good , with heat , Smokes up the shop when the job requires but never failed produce
#23 DougT OFFLINE
DougT
    Dog Approved
  • 7,152 Thanks
  • 5,103 posts
Posted May 22, 2015 - 06:50 AM
I have a buddy that swears by Breakaway. It is made by Cyclo.
#24 M.Cain OFFLINE
M.Cain
  • 185 Thanks
  • 158 posts
Posted May 22, 2015 - 03:12 PM
I use it 1/2 and 1/2 with shooters choice on my gun barrels good stuff I buy it factory direct by the gallon can. But in the shop I use P/B -Blaster
