Kroil?
23 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted May 13, 2014 - 08:27 PM
Anyone ever used Kroil?  Sounds like a good product. Just wana see if anyone else has had any luck with it before I buy some. Its awfully pricey. Thanks.
  • laurarg3 said thank you
#2 olcowhand ONLINE
  • 41,072 Thanks
  • 31,393 posts
Posted May 13, 2014 - 08:29 PM
We've used it a lot over the years, and good stuff.  I'm out of it right now & using PB Blaster.
  • superaben said thank you
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
It is incredibly expensive, and no better than PB blaster in my opinion.
I do know some guys that swear by it, though.
Ben W.
#4 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted May 13, 2014 - 08:33 PM
Seems to work good for me. It will definitely do as advertised and well worth the price IMO
#5 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted May 13, 2014 - 08:53 PM
We  use it at work , it works very well
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 13, 2014 - 09:13 PM
I used it in my rifles when i was target shooting. As you say it was expensive and hard to find in Des Moines.
A friend was using MMO and said it was the only cleaning oil that would not displace point of impact first shot from a clean barrel.
He was right. So I use MMO for any application I would have used kroil for.
It is much less expensive and available anywhere.
Edited by JD DANNELS, May 13, 2014 - 09:20 PM.
#7 MH81 OFFLINE
Posted May 13, 2014 - 09:23 PM
For breaking rusted stuff, it's the only thing I think is better than liquid wrench or homebrew.
Using a pump and buying it in gal qty is cheaper, the cans are nice, but $$$
Gibbs is another hard to find, but good penetrating oil, maybe not Kroil good, but close.
  • Alc and Texas Deere and Horse have said thanks
#8 Cvans ONLINE
  • 6,639 Thanks
  • 6,125 posts
Posted May 13, 2014 - 09:37 PM
Used to purchase Kroil by the 5 gallon buckets. We were in the meat processing business and corrosion was a constant problem. After I purchased the first small container we were sold on it. Screws that were corroded into aluminum junction boxes would come out. When the electrical contractors saw that they called it miracle squirt. It was good but calling it a miracle was a stretch.  :smilewink:
Since retiring I've switch over to MMO like JD Dannels. The darn stuff does a pretty good job and it is much more versatile than Kroil. Put it in Zoom oiler bottles with the long spout instead of spray bottles and it lasts a lot longer as you us less for each application. Use it my air tools with excellent results.
  • Texas Deere and Horse and KennyP have said thanks
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 14, 2014 - 07:36 AM
That's what we used exclusively in the Corps. We got it in the quart squirt cans.
#10 TAHOE ONLINE
TAHOE
  • 7,965 Thanks
  • 5,672 posts
Posted May 14, 2014 - 08:01 AM
A friend of mine gave me a little can of it, I think it works a little better that PB blaster and I was impressed with that stuff.
Sure wished it would loosen the axle bolt on my sears though, nothing is touching that thing.
#11 VintageIronCollector ONLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted May 14, 2014 - 09:13 AM
At my house we use Gibbs and it seems to well worth the price and can be used for just about anything. We also buy it by the case to get it at a cheaper rate. We also have some Kroil and in my opinion it works about the same as Gibbs and Gibbs is way less expensive.
#12 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,285 Thanks
  • 9,774 posts
Posted May 14, 2014 - 12:11 PM
I think 50/50 acetone and auto trans fluid is just as good as anything.
  • KennyP and Cvans have said thanks
#13 BillTheTractorMan OFFLINE
BillTheTractorMan
  • 205 Thanks
  • 288 posts
Posted May 14, 2014 - 12:41 PM
I only use kroil. There is no comparison, it is hands down better then pb or others.
Expensive but well worth it.
sent from my telecomunication device, from the seat of my imaginary tractor, working my imaginary feilds.
#14 IHCubGuy ONLINE
IHCubGuy
  • 1,510 Thanks
  • 1,590 posts
Posted May 14, 2014 - 07:38 PM
Have used kroil in the past and it is good stuff. We use Conklin "Rust Bomb" at work and I gotta tell ya it has free'd some things that I would have wrote of as hopeless. The stuff is REALLY GOOD!
https://www.conklin....06#.U3QYv4y9KSM
  • Cvans said thank you
#15 mopargoob OFFLINE
mopargoob
  • 56 Thanks
  • 40 posts
Posted June 22, 2014 - 09:38 PM
My brother used to be in the aircraft repair industry, specifically airframe, and he would share some of the stuff that was left over from jobs he did, (you cant put used stuff back in the bins,  a quality control issue).
he gave me half cans of Kroil, and does it work good!!
another one that works very well is Mouse Milk.  yes that is the actual name of it.
picture of a mouse inside of a nut on the side of the bottle.
Awesome stuff, very distinctive smell to it.
