Looked The 990 Over And I Have A Couple Questions.
30 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 13, 2014 - 06:54 PM
I have a lot of play in the front wheels. I wonder if they are spaced because they came off another gt?
The wiring appears to be mostly original. There are some ends that will get replaced asap.
Sent from my SAMSUNG-SGH-I437P using Tapatalk
#2 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 13, 2014 - 06:55 PM
Can you tighten the throttle? It won't stay up.
Does something go between the fenders?
  • Sawdust said thank you
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 13, 2014 - 06:57 PM
I wonder if the 3ph of the Massey? The one on the 990 seems poorly built. It doesn't have very much travel. The upper arm bracket seems low
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 13, 2014 - 07:35 PM
The steering wheel seems small when driving it. It's also hard to steer.
#5 TomLGT195 OFFLINE
TomLGT195
  • 4,103 Thanks
  • 2,930 posts
Posted May 13, 2014 - 07:38 PM
That's more than a couple. lol ( can't use emoticons). Tom
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 13, 2014 - 07:52 PM
A couple a few a lot it's all the same lol
  • TomLGT195 said thank you
#7 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted May 13, 2014 - 09:19 PM
I believe your should have 3 bolt hubs and wheel on the front. If you adjust the 3 pt links under the foot rests, it will increase the height  of the 3 pt and unless someone has the travel stop set low, it should pick up a good bit, mine did..I think you can tighten the throttle under the dash.
  • BairleaFarm and TomLGT195 have said thanks
#8 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted May 13, 2014 - 09:21 PM
I don't know what else could bolt on the rear fenders, you already have the tool tray that is usually gone.
#9 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 13, 2014 - 09:34 PM
The two holes above the tray has matching holes on the other fenders. After looking at pictures I saw some of the 990s had the 3 bolt hubs.
Is it hard to get the deck off? It looked complicated lol
#10 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted May 13, 2014 - 09:43 PM
The 3pt has alot of room for adjustment both in the length of the pull rods and the top link, the manual gives recommended settings for each attachment,
I use a tiller, 10' plough and a shovel type cultivator with my 960 and it has more than enough travel for each, more so than the Ford LGT series with either the 3pt or the sleeve hitch.
#11 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 13, 2014 - 10:45 PM
I was thinking about it and I bet my deck level setting its keeping it from moving is full range of motion.
#12 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted May 14, 2014 - 04:19 AM
I cant use both the deck and 3pt at the same time, the pins on the pull rods catch on the sissor lift, plus tiller and mower both use the same pto output, that why the deck is very rarely ever on my Columbia... pita. Not really a nice finishing mower anyway because of the way the front is always hanging from the sissor lift, I like a deck with adjustable wheels on all four corners.
#13 HALFSCALE OFFLINE
HALFSCALE
  • 520 Thanks
  • 543 posts
Posted May 14, 2014 - 08:29 AM
I notice that the hooks for your cross chains don't have inner nuts on, these get adjusted once an implement is put on to stop the side sway. A must when using a plow , planter or cultivator. The early 3pt's just fit sloppy in the holes ,the later ones went to the ball joint ends(79 and later) That's why you find a lot of these tractors with the ears busted off the rear , people bump the arm ends against something and they snap from leverage.        As for the rear section of your fenders, the tool box was an option, so kudos for having one , but the holes above were for the tail light panel, as far as I know they were only found on Whites, maybe Columbia but we don't see enough of them around here to verify. The Whites and Columbia's were a higher optioned and priced versions of the 990,
I know it can be a pain not having the 3pt separate from the mower deck , but it gives a good excuse to have a second tractor.
#14 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 14, 2014 - 08:59 AM
I think one of the first mods ill do is put the 3ph off the massey on this and put it separate from the deck.  I've got a few ideas like this I want to do.  I has access to torch's and welders now so that will make life easier.  Ive got to think about it as I want it to look like it could have been a factory option.  This girls deck goes high enough I could still use the rear grader blade, disc, and drag with the deck on.
#15 VTXrider OFFLINE
VTXrider
  • 551 Thanks
  • 399 posts
Posted May 15, 2014 - 02:52 PM
There are bushings in the wheels made of plastic and they wear rather quickly. Any end play is taken up with washers inside and out. I use a hairpin to hold the wheels on so it is easy to grease the spindle. New bushing are listed in the FYI file.
3 bolt hubs are from earlier models.
The throttle lever is worn if it moves by itself. Pull it out of the dash and determine what can be done to tighten it.
Nothing more between the fenders. I mounted a winch on a plate mounted across the fenders.
The steering is hard because it needs grease and lubrication. There is a grease point on the gear shaft and on each spindle. Also grease the pinion gear and section gear. Oil the steering rod ends.
Your tractor is about a 1979. You can download the manual from GTT or I posted it here for you.
http://1drv.ms/RW6hgv  Right click to download.
Attached is a small file with nice to know stuff about the 990, like part numbers and sources.
Edited by VTXrider, May 15, 2014 - 03:04 PM.
  • BairleaFarm, Sawdust and Bunker Buster have said thanks
