Kubota G4200Hst Tractor
9 replies to this topic
#1 Steve Moore OFFLINE
Steve Moore
  • 2 Thanks
  • 3 posts
Posted May 13, 2014 - 02:47 PM
Fuel injectors
  • 14,811 Thanks
  • 15,499 posts
Posted May 13, 2014 - 02:49 PM
Welcome to GTtalk. OK, I'll bite. What about Fuel Injectors??
  • 14,811 Thanks
  • 15,499 posts
Posted May 13, 2014 - 02:59 PM
Can you give us and idea what you are wanting to know or say about them?
#4 Steve Moore OFFLINE
Steve Moore
  • 2 Thanks
  • 3 posts
Posted May 13, 2014 - 03:03 PM
How do I clean fuel injectors
  • 14,811 Thanks
  • 15,499 posts
Posted May 13, 2014 - 03:11 PM
Steve, you can buy some good injector cleaner to add to your fuel and see if that helps. If that doesn't clean them up, you will have to take them to a Diesel Service shop and have them rebuilt. What is the tractor doing?
#6 Steve Moore OFFLINE
Steve Moore
  • 2 Thanks
  • 3 posts
Posted May 13, 2014 - 03:48 PM
Started up initailly drove it around the block. Turned it off.would'nt start back up.changed filters bled fuel lines up top. I think the injectors might need pulled out and cleaned did'know if someone had any tips? It sat for 2 years. Has new fuel in it now.Lucas fuel treatment also.
  • 14,811 Thanks
  • 15,499 posts
Posted May 13, 2014 - 04:22 PM
I would bleed everything again. Try bleeding each line while you have someone try to start it with the starter. You can break the line loose before you turn it over and tighten it back up if you don't see any air bubbles coming out. Make sure you tighten it up before you stop turning the engine over or you can get air back in the line.
  • superaben and TomLGT195 have said thanks
#8 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted May 13, 2014 - 06:01 PM
There is an inline fuel filter behind the right rear wheel.  Did you change it?
#9 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted May 13, 2014 - 06:02 PM
There is also a weird kill cable system attached to the roller under the seat.  If it is out of whack, it pulls the kill lever on the injector pump.  Make sure the lever is in the run position.
#10 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted May 13, 2014 - 06:11 PM
Make sure the kill knob is all the way back to the run position. If it is out just a little it can keep the engine from running.
