Bolens 1886-01 Running Hot
23 replies to this topic
#16 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted May 15, 2014 - 01:29 PM
I just sent you a PM about the top heat shield. The 2 1886's did not have them when I brought them home but they do now. When I repowered an 1886 with a 24 HP Honda I made a top heat shield for that type of engine.
#17 oddfirecj5 OFFLINE
oddfirecj5
  • 73 Thanks
  • 262 posts
Posted May 16, 2014 - 05:42 PM
fred could you send me a picture of how you did your honda top shield? [email protected]   i'm getting closer with my repower and wondering on a top shield.
#18 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted May 16, 2014 - 06:34 PM
Yes I can and I will but it won't happen until Monday. We have to travel tomorrow for a Granddaughter's college graduation. It was really pretty simple but it took me a while to figure it all out. The heat shield/reflector that Small Engine Warehouse sent was a farce. All that did was make the heat bounce back up under the hood. I even went so far as to cover the metal with ceramic insulation.
#19 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted May 21, 2014 - 06:57 AM
OK, rebuilt fuel pump. new coil, plugs, started just fine. ran for a bit ...10 minutes....then started to cut out, pulled choke out, ok...so its a fuel issue. removed bowl bolt, bone dry, removed fuel line, bone dry. petcock open all the way, new line, not collapsed, no restrictions. might just go ahead and put a 12v fuel pump in. Any suggestions?
Thanks
#20 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted May 21, 2014 - 11:26 AM
Thanks
Hmm does sound like a pump issue. That is what I would try based on what you have seen. So for just for the heck of it if you disconnect the inlet of the pump do  you get a good flow of gas coming from the tank? Just wondering if the petcock or line is plugged up at all. I had a gas line plug up once and that was the problem.
#21 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted May 21, 2014 - 11:32 AM
Husky,
  Removed fuel line from pump inlet, the line was bone dry. but after a few seconds 10-15, it did start flowing. blew thru line and petcock with air compressor. all open no debris at all. new fuel line, new fuel bowl, new petcock. tank was just flushed, no rust/debris.
#22 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted May 27, 2014 - 11:16 AM
Fixed. Mechanical pump bad. bypassed, installed electric, tore carb apart, cleaned, installed, started, no leaks, purrs like a kitten.
#23 oddfirecj5 OFFLINE
oddfirecj5
  • 73 Thanks
  • 262 posts
Posted May 27, 2014 - 04:26 PM
nice job!!
#24 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted May 27, 2014 - 06:54 PM
Glad to hear it was something simple, and nothing serious!
