Ford 195 Lgt
power steering
8 replies to this topic
#1 rabbit0y89 OFFLINE
rabbit0y89
  • 1 Thanks
  • 1 posts
Posted May 13, 2014 - 09:32 AM
deck goes up and down, rear end too full of fluid, no power steering.  HELP!!!!!!! :usa:
  • 14,863 Thanks
  • 15,511 posts
Posted May 13, 2014 - 09:35 AM
Welcome to GTtalk. Does it move forward and backwards?
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,015 Thanks
  • 2,883 posts
Posted May 13, 2014 - 09:42 AM
Welcome aboard. Not a hydraulic expert, but I would start with a fluid change using correct fluid. Change filter too. Then I would crack open lines at steering cylinder and make sure fluid is going in an out. Might be a bad cylinder?
Big question, did this problem just pop up, or was it there when u got the tractor??
As always pics would be nice as well as history of what you've done. Tom
#4 boyscout862 OFFLINE
  • 13,441 Thanks
  • 9,391 posts
Welcome to GTT. That is a really good tractor. Relax and enjoy the site. Post some pics and provide the guys with the info they need to help you. Good Luck, Rick
I found the Operators Manual in the Jacobson/Ford Section http://gardentractor...erators-manual/
Edited by boyscout862, May 13, 2014 - 03:43 PM.
#5 TomLGT195 OFFLINE
TomLGT195
  • 4,015 Thanks
  • 2,883 posts
Posted May 13, 2014 - 09:43 AM
Reminder about pics. I love seeing 195's. Tom
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 13, 2014 - 10:07 AM
Welcome to GTTalk. As noted, don't be shy! Give us some more info. and maybe some pictures. The 195 is a very nice tractor.
  • TomLGT195 said thank you
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted May 13, 2014 - 10:22 AM
:welcometogttalk: :wewantpics:
#8 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted May 13, 2014 - 10:33 AM
Sounds like the valve is stuck? It is attached to the pitman arm coming out of the steering box. It will have 4 hoses attached to it. This must move back and forth about 1/2" in both directions. It is what tells the cylinder to do when you turn the steering wheel.
#9 gitrdun OFFLINE
gitrdun
  • 64 Thanks
  • 42 posts
Posted May 14, 2014 - 11:58 AM
 this weekend i am going to remove the steering valve on my 195 because it is also stuck. i will let you know how that goes. doesn't look too hard to rebuild if there is no rust on the spool.
keith
Also tagged with one or more of these keywords: power steering
