Need Help Replacing Bearings On Mower Gear Box
25 replies to this topic
#1 tpevlor OFFLINE
tpevlor
  • 4 Thanks
  • 14 posts
Posted May 12, 2014 - 03:51 PM
anyone know how to replace the bearing in the mower deck gearbox?
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,458 Thanks
  • 5,765 posts
Posted May 12, 2014 - 04:15 PM
OK..  I'll bite...
Depends..  Which mower and deck are you discussing?  Helps to know what we are discussing a bit..
#3 tpevlor OFFLINE
tpevlor
  • 4 Thanks
  • 14 posts
Posted May 12, 2014 - 04:37 PM
Hello...and thanks for your attention.  The bearings are getting worn out in the gearbox on the mower deck. Ive been messing with it all day and cant seem to figure out how to remove them.  Its a K321S 14HP Kohler. older model...tag with model number is torn off so cant identify it specifically. It has 3 blades..the center one being driven by pto.
#4 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted May 12, 2014 - 04:47 PM
OK, now we know what engine it has on it, but WHAT BRAND & MODEL OF MOWER IS IT?
#5 tpevlor OFFLINE
tpevlor
  • 4 Thanks
  • 14 posts
Posted May 12, 2014 - 04:59 PM
Ok..my.. bad..guess I assumed ya knew it was Ariens..the factory sticker showing the model # is torn mostly off...no number...cant seem to figure out attaching a picture..it has a 46" deck..hydrostat...front pto with option to add rear...3pt hitch...deck is hydraulic lift...pto driven..it is an older model.....
#6 tpevlor OFFLINE
tpevlor
  • 4 Thanks
  • 14 posts
Posted May 12, 2014 - 05:09 PM
I managed to add this pic to my profile   ...hope it helps
#7 TomLGT195 OFFLINE
TomLGT195
  • 3,827 Thanks
  • 2,814 posts
Posted May 12, 2014 - 05:22 PM
Welcome to GT Talk.
I can't offer any help but someone here will. Check out manual section, might be some help there. Tom
Edited by TomLGT195, May 12, 2014 - 05:22 PM.
#8 tpevlor OFFLINE
tpevlor
  • 4 Thanks
  • 14 posts
Posted May 12, 2014 - 05:31 PM
thanks!   I'll do that right now...
#9 tpevlor OFFLINE
tpevlor
  • 4 Thanks
  • 14 posts
Posted May 12, 2014 - 05:39 PM
also...can anyone give me a guess as to the model number of this tractor??????     and maybe the year?    I bought it 10-12 years ago at an auction..it has Kohler 14hp motor...is K321S..hydrostat..front and rear (optional) pto..3pt hitch..46"deck...
#10 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted May 12, 2014 - 06:04 PM
Welcome to the site! I have no knowledge of Ariens so am not help there. Glad to have you on the forum!
#11 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 12, 2014 - 06:09 PM
You are going to need either a blind bearing puller or a good press.  It depends on the configuration of the spindle.
I'd pull it off and see if a good lawn and garden shop or machine shop can fix it for you.  It may be the easiest route.
Ben W.
  • HDWildBill said thank you
#12 tpevlor OFFLINE
tpevlor
  • 4 Thanks
  • 14 posts
Posted May 12, 2014 - 06:18 PM
thinking Im gonna hafta take it to the shop...wont fit in the trunk though..shoulda never sold that truck!!  Thanks for the welcomes though!!
#13 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted May 12, 2014 - 06:28 PM
Could you unbolt the gearbox from the mower deck?  It will much easier to handle that way.
Does this look like the same mower deck?
#14 boyscout862 ONLINE
  • 12,845 Thanks
  • 9,169 posts
Posted May 12, 2014 - 06:39 PM
Welcome to GTT. Take alittle time with our Galleries to see if there is a tractor that looks like yours. That may give you the identity, Post some big pics in the thread for us to better see what you have. Then you can find a manual and figure out what to do. There may be a way to clean and tighten up the bearings. Good Luck, Rick
#15 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted May 12, 2014 - 06:44 PM
Here is what you're dealing with, I believe: (click on the diagram to enlarge it)
When you say the bearings are going, are they making noise? Or is there play (wobble) in the shaft?
