Jake 1000 Super
2 replies to this topic
#1 Tomwendt ONLINE
Tomwendt
  • 137 Thanks
  • 149 posts
Posted May 12, 2014 - 09:40 AM
is there a vent plug on this hydro unit? i have fluid blowing out the input shaft seal.it leaked when i got it and i put in a new seal and still have this leak. thanks
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 12, 2014 - 10:34 AM
I'm not familiar with those tractors but I know a blocked vent will result in oil being forced out through the weakest point. In general terms the vent is normally going to be near the top of the hydro unit reservoir. I bought a JD314 and oil was leaking from the axle seals. I found that the vent filter was replaced with an unvented fuel filter allowing pressure to build up. An easy fix in that case.
#3 KennyP ONLINE
  • 38,256 Thanks
  • 45,876 posts
Posted May 12, 2014 - 02:57 PM
My 1450 hydro has a vent in the fill cap under the seat. I am not sure if all units had that. I uploaded a Service & Parts Manual just now.
