Sleeve Hitch Back Blade
5 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted May 12, 2014 - 05:17 AM
Im going to make a back blade for my 110 in the near future so can you post some pics of your homemade or brinly back blades?
  • tinbender7 said thank you
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,325 Thanks
  • 4,953 posts
Posted May 12, 2014 - 08:23 AM
Here is a modern blade I bought at a garage sale for $5.  I also have the box blade version of it but they are the exact same blade with just ends bolted on and a scrafier attachment added.
With down-pressure hydraulics on the Power King [pictured] it works surprisingly well.  The PK hitch is not quite right but it works so I just drop in a heavier grade bolt that will go all the way through and roll.  The bolt usually gets massacred and I have to cut the bolt to remove the blade.
I have a front blade on the that PK so I don't have to turn around and that works better for me.
Edited by Gtractor, May 12, 2014 - 08:38 AM.
  • hamman and superspeedex have said thanks
#3 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted May 12, 2014 - 12:19 PM
I actually like that better than the Agri-Fab box blade I have. Never could understand the need for the framework on top of the blade. I picked it up for nearly free a few years ago. It had been backed over and the fram on top, hitch and one end plate was badly bent. I just got it repaired and back together yesterday. threw a quick coat of black paint on it to use later. I may try to build a handle like that for mine. I'll try to get the camera to work and get a couple of pictures.                Roger.
  • superspeedex said thank you
#4 TomLGT195 OFFLINE
TomLGT195
  • 3,828 Thanks
  • 2,814 posts
Posted May 12, 2014 - 02:37 PM
Here's a homemade back blade that I picked up with a sears 3pt setup. I plan on converting to sleeve hitch . Hope pics help, Tom
Weighs about 70 lbs so dragged nice even on sears with just my hand for down pressure
Edited by TomLGT195, May 12, 2014 - 03:08 PM.
#5 MH81 OFFLINE
Posted May 12, 2014 - 06:11 PM
Here's my Brinly style
http://gardentractor...ork/#entry14165
#6 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted May 12, 2014 - 09:28 PM
Just what i was think will post updates
